Results 1 to 12 of 12
Thread: rb30 gearbox conversion
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default rb30 gearbox conversion
    rb25 boxes will bolt straight upto the rb30? what boxes are available for the rb30?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    ive got a r32 skyline 5spd on mine, not sure what motor was coneccted to it think it was the rb25 but from what my mechanic said its straghit swap and anybox will practical fit u jsut need the right bellhousing and braket/crossmember to hold the box up
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    r32 boxes are basically the same as the mf5 - n/a 5speed, generally not too much difference although they do seem quite strong.
    r33 5 speeds will bolt up to the rb30 with the old manual gear, only changes are tailshaft yolk, and the master/ slave cylinders need to be adapted, along with a speedo drive sender needs to be changed.
    any rb gearbox should bolt up without too much hassle
    Oct 2005
    Quote Originally Posted by Bax
    what you mean basicly the same? would there be any diffrence in the gear ratios or stuff like that or is it just the layout of the houseing?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Bax
    Nothing
    Jan 2004
    QLD
    Not quite sure on what the gear ratio's are like.
    I'm speaking in terms of strength, they are basically the same.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Oct 2005
    well in second gear i can get 130ks (r32 5speed), how tall would the stock 5speed get in second
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    it also depends on your diff ratio. but if diffs are the same i figure the rb30 box could be up to 20km/hr less than yours.
    Oct 2005
    if the box is taller then wouldnt that mean it will be slower at take offs? like diffs ratios
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    yeah probably not as quick on the initial takeoff but you'd get 70km/hr out of 1st.
    Bax
    Nothing
    Jan 2004
    QLD
    My old stocko would get around 120, but give and take a fair bit because speedo's vary and so do rev's apparently.
    Oct 2005
    Quote Originally Posted by bangers
    yah i can get the 70ks out of my first gear, so if i was to change the diff ratio to say 3.9 or 4.11 that would make the car run equivelant to a stock vl 5spd with 3.45 gears ?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. ??? RB30 manual gearbox ???
    By cohn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2010, 05:31 PM
  2. My VB - RB30 Conversion
    By madvb in forum VB - VC - VH - VK
    Last Post: 07-08-2010, 01:32 PM
  3. VB - RB30 Conversion
    Last Post: 31-10-2008, 10:04 PM
  4. vl rb30 5 speed gearbox parts? still available?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-01-2007, 07:42 AM
  5. VL rb30 block to rb20 gearbox
    By Slipinit_sideways in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2006, 10:28 PM
