Results 1 to 3 of 3
Thread: removing vl axles
    schoey Guest
    Default removing vl axles
    hey i snaped a axle tonight and started pullin it out un bolted the 4 bolts on the drum and droped the backing plate off and droped the oil but the shaft wont come out and help would be great
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by schoey
    They can be hard to get out, try putting on the spare wheel and you then can pull on the wheel to pull out the axle..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    reverse drum on studs, so lining is facing you.
    put 4 backing plate nuts back on till threads are showing through, so there's a bit of play in the drum.
    sit facing drum and yank towards yourself *NOTE, MAKE SURE CAR IS SECURE AND ON AN CAR STAND BEFORE DOING THIS AS IT'S NOT SAFE TO DO WHILE ON JACK AS CAR MAY MOVE AND FALL IF ON JACK*
    be safe while doing this, as it can be quite dangerous. but it's the only way i got my axles out.
    good luck
  1. VP IRS Axles
    By Reaper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2007, 09:37 PM
  2. Removing the KAT
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-10-2007, 12:04 AM
  3. quick questions bout vl axles
    By adrian222 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2007, 01:58 PM
  4. VN Diff Axles?
    By cohn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2007, 01:56 PM
  5. VQ and VS irs axles same?
    By stumps5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2006, 11:59 AM
