Results 1 to 12 of 12
Thread: Kill Switch
    maccona35 Guest
    Default Kill Switch
    Hey
    Ive heard kill switches are really good for protecting your car, does anyone no how to do it on a vl? what colour wire i have to cut ect
    cheers
    Maccona
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    depends which circuit you want to tap into. Fuel pump, starter motor, ignition system, its up to you. the easiest (easiest to fit and easiest to detect) is the starter motor power wire. otherwise you could probably hide one well for the fuel pump.
    vl berlina wagon 6cyl
    Jul 2005
    see also the antitheft ideas wanted post
    VLs are very easy to steal and are often stolen
    it also seems that almost any VL key will open and start any other VL, due to wear in the locks over the last 20 or so years
    danny_sway is offline danny_sway
    Vl commodore SL executive
    Sep 2005
    i can say this isnt always the case,
    ive got a vl na and a vlt and at least once a day ill jump in one and use the others key!
    they do get pinched as i can say i have gone through a couple of door locks and ignitions with no hope losers try to start one of them with a screw driver and a bit of force, but with both haveing a alarm central locking and 3 point immoboliser all on black wiring good luck to them, thats the best protection and u can get some security set ups pretty cheap these days, with awsome add ons like motion sensors ( i got in vl turbo set up cost an extra $60) cameras that take pictures when the alarm go off, and all sorts of novolties like that.
    ViciousLady Guest
    make sure you put the killswitch in a good non obvious spot, with my last VL i had the killswitch on and the f**kers still took her from me
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The killswitch for the injectors would be the best I reckon. Running to the fuel injection relay.
    ========My Statesman 20's Mafless and 3.9's========
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    as said before 'if the basterd wants ur car that much he will take it, no matter what'
    just a idea dont post details on your alarm/security sytems as there can be a low life reading this thread
    there is many ways to do kill switches
    in the ingition
    fuel pump
    gear selector
    in a efi relay
    starter motor
    etc
    just b wise where u hide the switch
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    maccona35 Guest
    is it easy to do a kill switch by yourself, i want 1 that wil give me good protection but no hard as to do. has anyone done 1 and can tell me how to do it?
    maccona
    Oct 2005
    Quote Originally Posted by maccona35
    maccona
    find the cable u want 2 use as the switch, cut two cables taht are longer enuf to get from the kill cable to the hiding spot of the switch, cut the cable thta is to be killed, solder 1 end off the cable to it and solder the other cable to the other severd part of the kill cable, run the cables to the hiding spot of the switch, solder them on to a suterble switch, and mount the switch, cover all solderd points with duck tape (black recommended) and if wanting to hide the cable more tape bother of the cables to gether with duck tape so it looks factory at first glance.
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    maccona35 Guest
    do you no what colour wires apply to what? i.e yellow is fuel and so on
    maccona
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    dude if you want something easy to install, without posting the particulars on here, then chances are its going to be an easy one to crack!
    Oct 2005
    Quote Originally Posted by vlv8vic
    yah agreed,
    ive wrote out the basics on how to do it you have to just figger out waht cable u are going to use as the 'kill cable' and then wire up, if u are looking for the cable colours try in a manual as i know gregorys has a wiring diagram near the bak
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. Kill switch
    By Conkster in forum Electrical Wiring / Questions
    Last Post: 15-04-2008, 05:54 PM
  2. kill switch
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 27-03-2006, 01:49 PM
  3. DIY kill switch
    By Pauly2478 in forum General
    Last Post: 25-03-2006, 03:36 PM
  4. kill switch
    By I LIKE COMMODORES in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 12:29 AM
  5. kill switch
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2005, 10:25 PM
