Results 1 to 7 of 7
Thread: Brakes/lights/cold starting
    Mar 2006
    Default Brakes/lights/cold starting
    [B]You guys are great crawl crawl. 3 kweschchns for yuzz !
    Any probs with 100 watt high beam globes in hedlite housing, ize countryfied so they can be glowing for awhile.
    Anyone know of modification or replacement of rear brake backing plate to facilitate adjustment of rear drums without removing them.
    Old girl runs ok but cold starts are a 2/3 go event, using juice also.
    Cheers Groucho (SW WA )
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    100wat bulbs could be a bit dangerous as if u use 2 high of wattage globe it draws to much currnt and it causes to melt the fuse rail in the fuse box. DONT put a higher rated fuse in the holder as it will cause the cables to super heat and run a chance of catching on fire
    i read somwhere in my owners handbook taht for cold starts in vls you slowly pump the acelirator down then back up before starting to activate the auto choke, this could help withj the starts for yah
    and using a bit of jucie hay? waht ks are you getting? there can be many causes, common 1s are AFM, temp sensor, CO2 sensor
    if these are off or dud then it makes tha car run rich
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    vl berlina wagon 6cyl
    Jul 2005
    in general, commodore electrical systems are only just strong enoutgh to handle normal demands, increasing the power of anything causes problems
    extra heat from stronger globes will likely cause heat problems to the headlight units, some separate driving lights, using a relay would be better, the standard lights were never thought much good, even when VLs were new
    did you take the lights apart, they are often dirty inside with the silvering damaged by heat
    to start a 6cyl VL from cold, turn on the ign and wait for the sound of the fuel pump to stop, be patient, a loud series of clicks points to the fuel tank being almost empty
    keeping the foot off the accelerator pedal, a short run of the starter motor usually gets it going first time
    Oct 2005
    Quote Originally Posted by harry3
    yah 'priming' as u described is ment to be done before you pump the pedal once to activat the choke
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The vl headlight lose their brightness over time (mine have) Instead of getting more powerful globes get a pair of new headlights and you will gain much better vision and they look sweet as well. I am gonna get some one day, its on the cards oh yes.
    ========My Statesman 20's Mafless and 3.9's========
    Jul 2005
    starting methods are different for the 6 and the V8
    the 6 doesnt have a choke, the fuel injection richens the mixture, keep your foot off the accelerator when starting the 6
  1. Gas-cold starting
    By brett 46 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2006, 11:18 AM
  2. Trouble Cold Starting
    By sharpeidog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2005, 07:12 PM
  3. Vn Calais starting problem in vey cold weather
    By lamb_ian in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2005, 01:32 PM
  4. Starting up my VS from cold........
    By comitnycrym in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2005, 07:31 PM
  5. park lights come on when brakes applied help
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2005, 04:46 PM
