I earlier posted a problem that i was having with my fuel pumps. I replaced the filter and the external pump(the old one was silent). The new pump kicks in everytime but the problem still exist. The car is running fine then bam!it shuts off. Sometimes it will start up right away other times nothing. I've checked the air flow filter and attachments, all good, all connections good. What is the problem, the regulator and if so how hard are they to replace.
sounds like your CAS. mine was doing the same and i thought it was the pumps too. Its more likely you aren't getting spark than fuel.
what are or is cas
Crank Angle Sensor, cost about 150 buclks to get fixed and auto electrisons can do it 4 u
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
not that hard to do yourself if you're mechanically minded.
can you test the cas prior to replacing it
check your ecu for fault codes. do the proper sequence and cancel out some of them. you may be left with 4 or 5 codes after that. the CAS will set off other codes too so if the CAS code comes up then its a good chance she's stuffed.
