Results 1 to 5 of 5
Thread: injector removal fun-need help
    thestash_16 Guest
    Smile injector removal fun-need help
    hey, i need to remove some injectors and replace them with some nice new ones. i started removing the screws and all that, but then i got stuck when it was time to remove the hose. does anyone know how to remove the hoses without damaging them??? i have searched through my manual and couldnt find anything.
    thanks for any help!!!
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by thestash_16
    Normaly cut them and replace the hoses..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The manual says cut the hoses because the new injectors will have new hoses or reco'd ones should have the hoses replaced as well. When fitting the new injectors make sure to put some petroleum jelly on the sealing rings and use a little fuel mto lubricate the hose when sliding it onto the rail.
    Which are you replacing? if all, have to take the top of the inlet off and it will be much easier.
    ========My Statesman 20's Mafless and 3.9's========
    thestash_16 Guest
    damn, the "newer" injecters are still in the plenum chamber in the shed, and i was hoping i wouldnt have to cut the hoses! oh well. also would the injectors have anything to do with a rough idle?
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Just pull the newer injectors off the fuel rail and cut the old ones off the car. You should always use new sealing rings when replacing injectors. don't cut the hoses on the newer injectors. Take the plenum off to remove them.
  1. VY Injector sizing
    By fmlycar in forum V6 Development And Modification
    Last Post: 16-11-2007, 04:54 PM
  2. Injector Job
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2006, 09:57 AM
  3. Injector help....!
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 02:04 PM
  4. Injector help please!
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 06:30 PM
  5. Injector Options
    By silvervl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2006, 06:26 PM
