Results 1 to 4 of 4
Thread: changing radiator fluid
    maccona35 Guest
    Default changing radiator fluid
    hey, how do i change my radiator fluid? i have no fluid left in the plastic contanier and ive heard its bad to mix fluids so i have to drain the radiator aswell, how do i do this?
    maccona
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by maccona35
    maccona
    Maybe the first question should be WHY is the overflow bottle empty???
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL SL 5spd
    Dec 2005
    you have to bleed the system by unscrewing some bolts etc. Too technical to explain but there is a thread about this.
    bleed valve location for cooling system
    vl berlina wagon 6cyl
    Jul 2005
    you can put water in the storage tank but you need to find out where the fluid is leaking from
    with the engine warmed up, stop the car and look for leaks
    changing the fluid is complicated, get a workshop manual, elleries isnt bad
    a new radiator cap is a good investment as these eventually all fail, allowing water loss
  1. radiator coolant low - fluid noise behind dash
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2006, 02:04 PM
  2. Changing brake fluid
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2006, 10:44 AM
  3. Changing power steering fluid
    Last Post: 30-07-2006, 08:31 AM
  4. Changing Clutch Fluid
    By Johnny_V in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-06-2006, 08:27 PM
  5. auto trans fluid changing
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2006, 05:16 PM
