Results 1 to 13 of 13
Thread: noise from fuel tank
    vl berlina wagon 6cyl
    Jul 2005
    Default noise from fuel tank
    My VL 6 wagon has a loud vibrating noise coming from the fuel tank, the engine still runs but I assume its the internal fuel pump on the way out or might something just be loose in there, am resigned to taking it out and looking, I have a workshop manual
    a fuelmiser brand replacement pump is abvailable for $130, are these OK?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Is it a constant "buzzing" noise? this is normal in all the vl's I have heard. If its a clunking/banging/knocking sound then you should check it out. otherwise it'll be fine. The pumps are very noisy for some reason
    ========My Statesman 20's Mafless and 3.9's========
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by harry3
    FuelMiser brand should be fine, has been around for years!!!
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jul 2005
    2 autoelectricians quoted $2oo for the pump and said pumps were hard to find and 200 to 300 for labor so I did it myself, lots of internel pumps around for about $125, the one I got came in a cooper box but was said to be goss??
    not easy without a hoist, siphoning the petrol needed a long hose and a bucket as the bottom of the petrol tank is close to the floor
    intrigued to see no insulation of electric terminals, I guess petrol doesnt conduct electricity
    have elleries VL workshop manual which was helpful
    all seems OK but were later some gurgling noises from tank, hopefully caused by some air trapped in the system
    theres a swirlpot in the tank that I couldnt see so I cam only hope the intake finished up in there
    a bit scary with all that petrol around knowing that only a single spark was needed for the big bang
    does anyone know for sure if the fuel system will still run on the high pressure pump only?
    also some say theres no low pressure pump in the sedans
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Goss have been making fuel parts ect. for years also and the gurgling was probabley air as you had fuel lines off and all VL EFI's have 2 pumps as far as I know..
    VL-187's Avatar
    VL-187 is offline ZZZZZZZZTUUUTUUUTUUU
    XR6 turbo 332rwkw
    Jan 2005
    yeh my old vl used 2 make the same noise..... i wouldnt worry bout it, probly be moe worried if it stopped making that noise...
    Jul 2005
    its a strange sucking or gurgling noise that seems to be from inside the tank and wasnt there before,it comes and goes but the engine runs perfectly any suggestions??
    also theres a trapdoor in the fuel filler line that the unleaded petrol pump nozzel has to push open when filling with petrol, the spring on it has gone so its not now closing, would this cause any problem?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Dont worry about the gurgling noise mine did this the whole time i owned it. It mainly did it when it was low on fuel but never caused any probs.
    VL SL 5spd
    Dec 2005
    Jul 2005
    interesting site thanks
    I think I may have wrongly positioned the pump so its not in the swirlpot, but it seemed to only want to go in the one way
    anyone actually replaced the pump in the fueltank?
    theres a gauze filter on the intake of the pump which can become blocked but wwas clean in mine
    VT SS S2 A4
    Aug 2005
    Jul 2005
    I took the internal pump out and put it back and now all is OK, theres apparently a swirlpot in the tank and the pump needs to be sitting in it, it cant be seen and I couldnt feel it, this time I positioned the pump with the bolts loosely done up and moved it up and down several times
    along with the noises, the car ran short of petrol earlier, it lost power but kept on running very slowly
    I think the fuel from the return line runs into the swirlpot, anyone know about this??
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Yes the return line goes through the swirlpot and is swirled down into the tank.
    Can't remember the reason why tho.
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 04:29 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  3. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
  5. vl fuel tank noise
    By driver in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-05-2005, 09:11 PM
