Results 1 to 10 of 10
Thread: VL clunk sound when braking
    STYALR Guest
    Default VL clunk sound when braking
    hey guys im buying my cousins vl off him wen u go 2 brake cuming from the back of the car there is a CLUNK sound onli wen ur about 2 brake wat cud it be and is it a big problem? its not overly loud u just hear it a lil
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Is it disc rear or drum??
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    STYALR Guest
    not sure wat it is sorry wether its disk or drum wat wud b the problem on both if it were making that noise?
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by STYALR
    might not be a brake prob, could be a bush.
    does it do it if u put ur foot down and then back off or only when u touch the brake??
    STYALR Guest
    Jun 2005
    South OZ Adelaide
    just wen braking thats it man
    Just guessing as can't see it or hear it, If it's drum rear could be loose backing plate or if disc rear could be loose caliper..
    STYALR Guest
    Jun 2005
    South OZ Adelaide
    Disc brake looks like this and drum like this..
    Attached Thumbnails Attached Thumbnails VL clunk sound when braking-disc.jpg   VL clunk sound when braking-drum.jpg
    Jun 2005
    South OZ Adelaide
    ok thanks man thanks for helpin cheers
    No problems.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    it could be a sticking wheel cylinder or piston depending on what rear end you have. if thats the only problem then don't let it discourage you from buying the vehicle.
  1. Braking Problem
    By MUNTED6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2007, 11:16 AM
  2. Strange sound under heavy braking VXII S
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2005, 11:35 PM
  3. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
  4. VT Jolts when braking...
    By chris239 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2005, 10:15 AM
  5. Problem while braking.
    By abzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2005, 08:57 PM
