Results 1 to 13 of 13
Thread: Info on a VL Shift Kit?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Default Info on a VL Shift Kit?
    Howdy, one of my mates has a VL that he wants to get shift kit for his automatic trans...
    Now i was wondering if any1 here has had one put on their car and if they are worth the money?
    He wants to know how much they cost and who sells them, as well as if they come in the same stages as other commodore kits...Stage 1 for towing...stage 2 for hard shifts for street and stage 3 which is a fully manualised auto box?
    Any help would be great, thanks in advance guys
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    any trans place should be able to do it for you, and all shift kits are ranked in teh order as stated, i think i can recal a mate getting his calais done for 300 with a full trans service
    and for the question is it worth it, o yeh because if your chasing power then the stock box wont hold for long, this will tuffn it up a bit and it will make the box last long because it reduce the chance of sloppy gear changes thus lease wear and tear
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    1991_Vn2nV's Avatar
    Mar 2006
    Ah ok. See my mate got one in his VR Calais and i told me mate with the VL to go there as well.....but they told him that you cant get a shift kit for a VL. Guy said he has been doing this for 18 years and has never once seen a shift kit for a VL...Yet i know they make them, so I guess i will send my m8 to another transmission place.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I will get the info for ya, from what I've read up on it, its not really worth getting a "shift kit" for the Jatco because the end result isn't as impressive as say a turbo400. But there are other ways around this.
    :from calais turbo:
    There is no such thing as a shift kit for the Jatco auto.
    A trans shop can modify the valve body to provide firmer shifts etc, but this is not a shift kit. The first thing to improve the shift cheaply is to up the pressure in the valve body by changing the main pressure spring.
    And I also read somewhere about changing/removing/blocking the overdrive cutoff solenoid. I will hunt for this info later on.
    ========My Statesman 20's Mafless and 3.9's========
    VT SS S2 A4
    Aug 2005
    SUSPECT's Avatar
    SUSPECT is offline Banned
    SUZUKI GSX-R 1000 k8
    Aug 2005
    adelaide, southern suburbs
    mmmm i was gonna get a shift kit but..... if u do get 1 it puts a fair amount of stress on the rest of the drive line, diff, tail shaft etc wont break stuff at first but after a while stuff will start 2 show signs of wearing
    thats from my experience so might not b the same as urs
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I suppose if you don't give it shit every day it will last longer. If you try to avoid chirping 2nd with sticky rubber on you should also be ok.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by ucwepn
    Knowing my mate, if he can chirp second he will.... But thanks for all the info! Whats the difference with the Turbo VL auto to the normal Jatco one?
    dobbie Guest
    VL
    Jul 2005
    SA, Mount Gambier
    Quote Originally Posted by SUSPECT
    I aagree however, if you have the power in your motor, a tuff gearbox that chirps :P, then why wouldnt you spend money on your diff etc?
    VT SS S2 A4
    Aug 2005
    SUSPECT's Avatar
    Aug 2005
    Quote Originally Posted by adox
    tis tru but if u dont have plans like putting a turbo on then do it.... like if u have a vlt... then u will do somthing 2 the trans but if its just n/a and u only have minor mods like exhaust, headers then there is no point!
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    There is always a "point" all the mods add up eventually. The diffs are fairly hardy only thing is might twist the 2 piece tailshaft or drop it. or twist or snap an axel. It depends on the driving style, the tyres,the condition of the driveline and the road at the time. Also depends how hard you want it to shift.
  1. Shift Kit for VR Ute
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2008, 08:19 PM
  2. when 2 shift?
    By aquabog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2006, 11:41 PM
  3. anyone with shift kit
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2006, 01:23 PM
  4. wat dus a shift kit do
    By pro1438 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2006, 04:44 PM
  5. LSD, SHIFT KIT,HIGH STALL PRICE - Info For Commodore Owners.
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2005, 12:29 AM
