Results 1 to 6 of 6
Thread: Noise comming from back of car when over 70-80ks
    VE Lumina
    Mar 2004
    Default Noise comming from back of car when over 70-80ks
    I'm presuming this is the diff on the way out? I'm certainly not very mechanically minded so I'm not sure if it is the diff or not. If it is the diff is it hard to take the diff off and replace it?? For someone who doesn't know much about cars I manage to work out how to do things. In the past week I have taken my stock exhaust off and replaced it with pacemaker extractors and a 2 1/2 inch exhaust system. Will a N/A auto VL diff work in my N/A manual VL?? I have rung wreckers and they only have auto diffs for around $100 and said they don't know if an auto diff will effect my manual gear ratios??
    I would appreciate it if someone would help me out abit on whether it is easy enough for me to have a go at replacing it, and whether an auto diff will be fine for my manual vl.
    Thanks in advance
    Josh
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    auto and manual diff's are the same as far as i'm aware with the n/a 6's, also the auto diff would be a good choice since it's more likely to have had an easier life..........
    VE Lumina
    Mar 2004
    Ok thats good, atleast I don't have to go searching for a diff from a manual VL. Is it very hard to change the diff???
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    just depends wahts rong in there,
    simple if its just the crown wheel
    remove rear axels
    take bakking of housing off
    remove bolts and pull it out (crown wheel)
    if u need more help a write up is here,
    http://www.calaisturbo.com.au/showth...t=open+wheeler
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Aug 2005
    Queensland
    no, it's not hard at all, get some axle stands to hold the car up with so it's stable and go nuts.
    also it'll make life a lot easier if you get a strong mate to help you, it's a prick to do by yourself
    vl berlina wagon 6cyl
    Jul 2005
    talk it over with a diff specialist first
    check the oil level in it, remove the rubber filler plug, put in your finger, bend it down and use it as a dipstick wwait a while after driving it or the oil will have air bubbles in it, which expands it
    check the breather to make sure it isnt blocked by hardened mud
    try using a tap recorder left over the diff on the floor to record the nosie
  1. Wurring noise at 60km/h in the back?..
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 02:03 PM
  2. Back End Noise
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2005, 08:12 PM
  3. Clunk noise from the back
    By scbh81 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-07-2005, 09:57 PM
  4. Weird Noise Coming From Back End
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2005, 02:48 PM
  5. Noise in back end
    By andrew in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2005, 10:40 AM
