Results 1 to 3 of 3
Thread: VL voltage meter not registering
    VL Berlina
    Aug 2005
    Default VL voltage meter not registering
    after having the battery on the charger yesterday, I've noticed that the voltage meter does not register. When the motor is started the needle moves fractionally at the low end of the red scale but not any further. All I did was disconnect the neg earth lead then the pos lead prior to charging, then recon after charging. Can you pls help?
    Mar 2006
    VL s are notorious for bad contacts on the positive wire bundle at the battery term. end>Clean all wiring harness plugs and terminals and try again.Use spray contact cleaner if you can afford it .Good luck.
    VL Berlina
    Aug 2005
    Default VL Voltage now registering
    Thanks groucho, the fusible connectors were especially dirty. Seems to work OK now.
  1. in need of some voltage!
    By Lowwwerd vs in forum Electrical Wiring / Questions
    Last Post: 20-11-2007, 03:19 PM
  2. VL voltage meter not registering
    By grazm in forum Electrical Wiring / Questions
    Last Post: 02-06-2006, 06:54 PM
  3. voltage regulator
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2005, 04:18 PM
  4. system voltage
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2005, 05:12 PM
  5. registering v8 in VIC
    By manvr in forum General
    Last Post: 01-08-2005, 10:25 PM
