Results 1 to 3 of 3
Thread: Fuel issue
    Mar 2006
    Default Fuel issue
    Greetings Commodorians,
    Pressure not builing up in tank. Should it ? Engine bay smells fuelly but no obvious leaks.Harder to start cold,otherwise runs fine, bit heavy on petrol.Tried changing caps(new One). No difference.Any ideas out there?
    Cheers Groucho.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by groucho
    Cheers Groucho.
    im not possitive but i think there isnt ment to be any presure in the tank as it runs off two pumps a high presure pump(inside) and a low pressure pump(out side) to suply the fuel
    how many ks u get a tank?
    as for usage could be a few things causing exessive fuel usage, AFM, o2 sensor and temp sensor, if these are old and not working well tehy can cause the computer to make the car run rich causing execcive fuel usage and possible the reson for the petrol smell
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vl berlina wagon 6cyl
    Jul 2005
    get a mate to drive behind you and look for black smoke from exhaust which of course means its running rich
    its normal for the inside of the tail pipe to be black, BTW
    remember that all the rubber hose parts of the fuel system are about 20 years old so plan on replacing them with the correct high pressure fuel hose, buy a metre of it
  1. Fuel Pump issue
    By Ton-Fun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:04 AM
  2. Fuel consumption issue
    By Roh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2006, 08:31 PM
  3. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  4. fuel tank issue
    By Gladiateher in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-06-2005, 09:49 PM
  5. Fuel Issue
    By jetspin_vn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-01-2004, 05:13 PM
