Results 1 to 5 of 5
Thread: Demister Relay
    VL SL Sedan
    Jun 2006
    Default Demister Relay
    Vl SL SEdan.
    My rear window demister has stopped working. I have checked the fuse (ok), the switch is working and the demister LED turns on/off when the switch is pushed. I am not getting any power to the demister itself.
    With the fan fuse removed, I can hear a relay operating somewhere behind the dash, but can't locate it. There is supposed to be a fuse and relay panel by the drivers right leg, but this has been replaced by a solid state assembly (original). Found the indicator relay tucked away near there, but still can't locate the demister one.
    Anyone know where this relay is? It's infuriating to be able to hear it, but not find it.
    Thanks, Chris
    executive vt 5.0lt
    Feb 2005
    west suburbs
    it may be the back window demister wires, onthe glass, are broken, and not macking a cercit ,thats what has happend to mine
    VL SL Sedan
    Jun 2006
    Quote Originally Posted by gungazza
    I'm not getting power to either of the wires that plug into the demister itself, so it seems to be a relay contact problem.
    VT SS S2 A4
    Aug 2005
    I think you need to visit your local auto electrician, mine is exacally the same.
    VL SL Sedan
    Jun 2006
    Default Found It
    Rear winder demister module. A black plastic box (sealed), is screwed to the right hand panel, beside the drivers right leg, behind the bonnet release cable. Unit is about 140 X 100 X 30. Pig to find, because the sound insulating felt is glued to it, and conceals it.
    It has 3 plastic lugs for screws, bottom, front, and top. Has 2 multi wire plugs in the top. Got one from a wrecker, and demister is functional again.
    I think this unit also does the wipers.
    I can post a photo if you want, but you need to look under the felt.
    Chris
  1. rear demister
    By mws in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2007, 06:21 PM
  2. demister grille
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2006, 06:59 PM
  3. demister not working! :(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2006, 06:59 PM
  4. vr rear demister
    By POZ-468 in forum Electrical Wiring / Questions
    Last Post: 03-05-2006, 09:12 PM
  5. Demister?
    By vsmanny in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 08:21 PM
