Results 1 to 9 of 9
Thread: inside rocker cover
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default inside rocker cover
    i have a rocker cover i'm sending off for either polishing or powder coating. but inside is a metal insert thats welded in, sort of like a windage tray. does anyone know if its normal? also i suppose sanblasting is now out of the question now as sand particles will get stuck in there even after hosing so may get into oil causing dramas, would this be correct?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by bangers
    That metal bit is called a baffle and stops drops of oil getting sucked in..
    As 4 sand blasting, clean with comp/air and wash, wash, wash..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    a couple of grains of sand will not kill your engine but you should still clean it all out about 50 times before putting it on the car. There are small metal fragments inside your engine right now floating about until the filter attemps to pick them up.All engines have metal fragments floating around them.
    ========My Statesman 20's Mafless and 3.9's========
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    cool cool. i didn't really want the thing polished like everyone else. i though the rocker cover and timing cover powder coated gun metal colour on a black block would look tidy. with a few other bits in chrome and aluminium would look nice.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    You can soak it in degreaser, but thats about as far as I'd take it. Paint stripper/ sandblast the top later and away you go.
    Post up pics when your done, mine should be done soon.
    dan_man31's Avatar
    dan_man31 is offline now projecting oh yeah :D
    vl executive
    Feb 2005
    brisvegas
    yeah i hand sanded mine got carby spray and sprayed the cover with that took off the paint really well then lots and lots of sanding came up really nice just used a really heavy cutting paste with the buffer in between sands it came up sweet then hit it with some autosol from supercheap or repco took all up a day's work definetly worth it though but yeah pressure cleaned it and things like that as well. here is some pics
    Attached Thumbnails Attached Thumbnails inside rocker cover-801052_10_full.jpg   inside rocker cover-801052_11_full.jpg   inside rocker cover-801052_25_full.jpg
    Its Stock And it Rocks .... ditch the bitch lets go racing
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    yeah i don't mind the polished look but i think i'll go with gun metal powder coat with the timing covers the same. it shoiuld look good on a black block.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    so do the covers just unscrew off easy, nothing much else to remove to get access?
    might look into getn a secnd hand 1 from the wreakers and get it sand blasted by my dad at work, then paint it at work my self
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Bax
    Nothing
    Jan 2004
    QLD
    Yeah just take off your inlet piping, the black plastic piece and disconnect the other bits, there are rubber seals that are under the screws with washers, put them aside. Also a rubber gasket that sits in a channel beneath the cover. Make sure it is still intact and not perished.
    Then take off. Easy as really
  1. Rocker cover gaskets
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2007, 10:58 AM
  2. rocker cover question
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 10:50 AM
  3. VL Rocker Cover
    By Bax in forum Swap / Wanted to Buy / Trade
    Last Post: 21-05-2006, 11:59 PM
  4. rocker cover gaskets
    By AnthsVSLexcen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2004, 12:19 PM
  5. 202 Rocker Cover
    By vkberlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2004, 11:26 PM
