Results 1 to 10 of 10
Thread: Tps
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default Tps
    whats the difference between the TPS on an auto and a manual?
    Jan 2004
    Auto transmission TPS: contains two sets of contacts, one set monitors idle position and the other set monitors full throttle.
    Manual transmission TPS: contains only one set of contacts, to monitor idle position
    -Mick
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    another question:-
    when you do a gearbox conversion does the TPS need to be changed? or only if you change the ECU to a manual ECU as i was planning on keeping the auto ECU cos it has a chip in it.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    from what i can figure out i can leave the auto TPS on as i am closing the neutral switch so the car will always think the car is in neutral. The auto TPS only drops the revs when you put it into neutral cos it has an idle wire. So effectively the car will idle like neutral when the clutch is in as it doesn't need a higher rev to hold gear like an auto anyway.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i've wanted to know the same question but ppl just been blabbin their technical bullshit at me, chek this out
    "Its not absolutely necessary but definitely advisable. The auto runs a variable resistance TPS whereas the manual TPS is an on/off switch type. The auto TPS is used in conjunction with the auto ecu to map the fuel input by the injectors."
    ... that dont mean much to me, i have to think to know what it means ... i dont like thinking at all
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    i recently found a plug dangerling from the loom near my oil filter, i found out that it was ment to be conected to my TPS but when i got teh motor and box swaped over it wasnt need as it was diffrant wires, so i think if u do the box swap u must swap the TPS or u will have to mod the cables
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Oct 2005
    and im pritty sure ive got the auto ecu still, is there any wasy of telling on the out side of the ecu?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Dec 2005
    Nsw - Taree
    i have both auto and manual here, i'll compare the 2 tomorrow if i remember
