Results 1 to 22 of 22
Thread: how to clean the over flow
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default how to clean the over flow
    best way to clean the over flow bottle out?
    ive got sludge inside it and it ugly wanna clean it off but i cant reach in with my finger to rubb it off
    tryd water, hot and cold
    easy of BAM shower clean thingo (rinsed it out well after)
    need more ideas how to do it....
    i dont wanna use blanch as that is a last resort, and it might not even work
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    try a bent piece of wire with a rag or cloth on the end...just bent it accordingly to where u want to clean...while attempting to run a hose through it at the same time...i think we used a screwdriver one time...
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    VT SS S2 A4
    Aug 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Go to the safeway and buy a brush for cleaning babies bottles, make sure its a decent one tho because the $1.50 ones will fall apart LOL.
    ========My Statesman 20's Mafless and 3.9's========
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    when i worked at holden we used to put a handfull of nuts and bolts it it with a small amount water. cover the hole up and shake the sh:t out if it. empty the dirty water out of it. Do it again if you need to. MAKE SURE THE BOTTLES ARE IN GOOD COND AND NOT BRITTLE.
    vl berlina wagon 6cyl
    Jul 2005
    on my VL the plastic cracked, allowing all the water to leak out which eventually caused severe overheating, needing a reconditioned engine, the owner didnt believe in checking the temp gauge or any water levels
    Oct 2005
    Quote Originally Posted by big_stretch
    thats what i did, metal coat hanger with a old sock duct taped on, worked a treat but the plastic is like a staind yellow from its age, any thing i can do to make it whiter????
    i cleaned the out side of the bottle with a old tooth brush and some whiting tooth paste and it cleaned it up well, got all the dark marks off and it smells fresh
    LOL at harry3, got to be hating those 'drive till it stops ppl'
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Ya can paint them as well, colour of your choice haha I'll let you choose. I'm gonna do mine but wanna see what colour i'm gonna paint my rocker cover first and do the bottles to match, its not like you can really see through them anyway aye.
    Also thinking about a hose sleeving kit but need to replace a few hoses first so I know they wont need to be replaced.
    Oct 2005
    Quote Originally Posted by ucwepn
    exactly what im doing
    washer bottle will be painted white, im going to mask a vertical line of tape there so i can see the levas when i peel it off
    cleaned up some cables this weeknd i did, making it neater
    getting a s/hand rocker cover soon, getting it sand blasted by my old man then ill get it painted at work
    and changing my intake pipes back to black
    repainting my air box top white again and same witht he fuse box lid
    curnt look, but exept the over flow bottle there was dirty
    Attached Thumbnails Attached Thumbnails how to clean the over flow-picture-123.jpg
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Oct 2005
    Quote Originally Posted by POVRTY
    are these bottle pressurised? thus the reson u say that above, or just so they dont leak then ur system drys out
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by VL Berlina 5speed
    No not pressurised, they were just saying if it brittle it'll break up...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VT
    Apr 2005
    QLD
    squirt a tiny bit of morning fresh in there (lemon optional) some water and a handful of sand and do your best tom cruise '****tail' impression.....worked for me.....that was a few years ago, but now i'm old enough to just buy a new one....
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    CLR
    Calcium, Lime, Rust. Thats what I've always been told.
    Even a minor dose of acid and water + gloves, give it a quick swirl.
    The nuts and bolts and water sounds brilliant. They do discolour easily though, mines been sitting downstairs, brand new, and its discolouring already.
  15. #15
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i reckon 3 shakes doin the nuts and bolts thing and i would have a big hole in the side lol
  16. #16
    Oct 2005
    Quote Originally Posted by BigDaz
    same,
    thus y the sock on a wire was the way i went
    so any1 got a good idea for whiting the plastic?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  17. #17
    VL SL 5spd
    Dec 2005
    I got a new one on eBay for $70 including postage. a bit expensice but I hate the look of the ugly 19 year old disgusting bottle!
  18. #18
    Bax
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by Henerz
    Is it now that I tell you Holden sold me my last one for 45 dollars?
    And the one before that for 45 dollars?
  19. #19
    VT SS S2 A4
    Aug 2005
  20. #20
    Oct 2005
    not happy jane....
    my local holden dosnt stock vl parts any more
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  21. #21
    VL SL 5spd
    Dec 2005
    WTF! damn I thought they didn't sell them anymore!
    all Holden dealers sell them?
    fcuk fcuk fcuk fcuk fcuk!!!
  22. #22
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    I cleaned mine with hot water and ball bearings. then shake. mine was grubby and slimy (about 10-13yrs of build up) so i sprayed degreaser and used a bottle brush. then rinse out a few times with hot water. came up like new, but slightly discoloured.
  1. best way to clean??
    By VZHSV in forum General
    Last Post: 03-10-2007, 06:44 PM
  2. Clean 95 Vs
    By Ghost79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 01:01 AM
  3. carbon clean/injector clean
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2006, 10:24 PM
  4. How to clean t/b
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2006, 09:32 PM
  5. F/S: Very clean 93 VR
    By Shifty1 in forum Parts And Other Items For Sale
    Last Post: 02-05-2006, 02:12 PM
