Recently after pulling up there was been this smell come through the car via the vents, and you can smell it when you get out, i was told i could have been the injectors, does anyone have anymore information in regards to this, a possible cause or solution???
Is it infact the injectors???
A fuel smell could be the result of leaking injectors.
Just take a look around the hoses?
Have a look around the injectors and see if theres a redish stain, if there is they are leaking..Originally Posted by Thorney_86_VL
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
what kind of smell is it? it could be one of many things. An eggy kind of smell could be the cat. A burning kind of smell could be the transmission or brakes. There are more things that can make funny smells, I fitted 2nd hand extractors on my old torana and they smelled for ages.
Its the Eggy sort of smell, when you pull up, stinks like holly hell, you can smell in and outside the car, i was told it could have something to do with the injectors, and its def not the burning smell
have u ahd ur exhasut done lately cos my car stunk like that for about a month lol and i found out thats its just the protectant paint on the exhasut and stuffs burning off
[SIGPIC][/SIGPIC]
I 2nd that motion..........Originally Posted by ucwepn
" Behold the turtle. He makes progress only when he sticks his neck out "
yer i forgot to say i got a new cat when my exhaust was done too
[SIGPIC][/SIGPIC]
Is there anything to look for in regards to the Cat, or just rip it out and replace
Did you check the injectors?
You can tap on the bottom of the cat and see if it sounds hollow, the guts is known to fall out of them and that causes the smell. Take it to an exhaust place to get checked if in doubt, they shouldn't charge you anything to have a look at it for ya.
Its def not the injectors, there in top order, ill take a look at the cat tomrrow, might pop around to Midas
