Results 1 to 4 of 4
Thread: VL Problems
    '87 VL Berlina
    Sep 2005
    mostly in my car
    Exclamation VL Aircon Problems
    Hey, i got my VL a few years ago... when bought, all my aircon hoses were disconnected. the only number that i have on the hoses is 3, so this could be an issue. does anyone have a diagram or anything for me to be abel2 to hook them all back up right ? because i have no windscreen de-fogger thing, wateva its called, and its getting cold and my windscreen is starting to fog up heaps good. any help wud be appreciated
    1JZ-GTE VL SL
    May 2005
    Number three (3) Goes into the recirculation valve right near the blower fan.
    Number four (4) Goes through the firewall and connects to the engine (Vac supply)
    Number five (5) Goes to a small one way valve (White and black round thing) on the drivers side near the firewall and disapears behind the heater box.
    Number eight (8) goes to a actuator near the steering coloum with a rod and a lever on it, its close to the front of the dash and i think the lever pushes down.
    Number nine (9) goes to a actuator behind the ciggie lighter area.
    Everything else has a rubber blocking teet on it, all up i think there was four.
    dibly1980 Guest
    Im having the same problem except mine are disconnected behind the control panel and none of my tubes are numbered?
    1JZ-GTE VL SL
    May 2005
    it won't be that difficult just trial and error, pull the dash appart (just what you need to ) to access the tubes, start the car and you should be able to find the one that has vacum (i think it goes in the centre) the try the other lines on only one port so you can find what vent they control, then plug them all in to where you believe they should be and test all the settings. This will probably take about 1/2 and hour max.
  1. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  2. VK problems - HELP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2006, 03:25 PM
  3. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 08:50 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 03:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 12:04 PM
