Page 1 of 3 123 LastLast
Results 1 to 25 of 73
Thread: VL commodore suspension question
    broadtail is offline broadtail
    VL Executive
    Jun 2006
    Mudgee NSW
    Default VL commodore suspension question
    Hi to all, I'm new to this and I'm a VL commodore owner with a couple of questions to throw in the ring for comment -- I'm broadtail and would like to know 1] my vl has 15" wheels and I would like to know if vp commodore mags, also 15" would fit my vl. 2] my son inlaw and friends gave this vl a bit of a ruff time, and I have taken over the car and would like to fix it up some-what as I had to sell my Ford to help my wife's cancer treatment, don't laugh yes a Ford, but I have a certain respect for both cars as they both have their good and bad sides, mind you its the fist time I've owned a holden and must admit the vl is more than I expected and economical, anyway I want to fix a suspension alignment problem, which apparently requires a new set of struts, which, I have had trouble finding undamaged or bent sets, anyone out-there know if struts from any other model commodore can? be used in a vl. would appreciate any help cheers broadtail
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by broadtail
    Not sure on that 1, but I know the springs from VB-VP are the same..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL Executive
    Jun 2006
    Mudgee NSW
    thanks Mag, I believe that there's various componants that were used but as I stated my first holden , so I've a lot to learn. broadtail51
    VL Calais Turbo
    Aug 2005
    The VP rims will definately fit as all Commodores share same bolt pattern etc so that wont be a worry. Buying new struts might not be as expensive as you think either so price em up.
    VL Executive
    Jun 2006
    Mudgee NSW
    thanks kalais6, was told by GMH agent struts no longer available. broadtail51
    VL Executive
    Jun 2006
    Mudgee NSW
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Front or rears, You should be able to get them new from a tyre/mechanical, or suspension place for rather cheap.
    If all else fails, the site shop may be able to help, or ebay if your desperate.
    I'll give you the word of advice in saying don't go to Holden for parts, they charge an arm and a leg, as good as genuine is, its not worth the cost sometimes. If its an engine component, try Nissan aswell when getting quotes.
    Repco are good too.
    VL Executive
    Jun 2006
    Mudgee NSW
    many thanks Bax, I've actually learnt that gmh is last on my list unless no alternative.
    VL Executive
    Jun 2006
    Mudgee NSW
    Hey Guys , I still have had no answer on whether the strut assembly [ not the inserts ]from previous commodore models or after vl will fit a vl commodore as the assemblies are not being sold any longer and most wreckers have damaged ones , any Help is appreciated
    Bax
    Nothing
    Jan 2004
    QLD
    I honestly couldn't tell you, keep an eye out on here and calaisturbo.com.au
    Somebody would have secondhand shocks for sure, with the amount of people that lower their cars. I had some a few weeks back but I binned them instantly.
    VL Executive
    Jun 2006
    Mudgee NSW
    Quote Originally Posted by Bax
    I can get the shocks no probs its the strut assembly itself I am trying to find. thanks Bax
    VL Executive
    Jun 2006
    Mudgee NSW
    Question VL strut Assembly
    Anybody in the know??
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    just ring around some suspension places they can be very helpful with advice and questions. I have a feeling they would be the same because they take the same springs and shocks but they may be different. Better to find out from the experts and be sure about it. Yes all commodore rims fit all commodores but the offset on VS or VT onwards is different although they will still fit it will make the car "tramline" or "bump steer" more than the correct offset would. Although with 15 inch wheels you prolly wont get that.
    ========My Statesman 20's Mafless and 3.9's========
    VL Executive
    Jun 2006
    Mudgee NSW
    Thumbs up
    Quote Originally Posted by ucwepn
    Many thanks ucwepn, I've rung around , spoken with mechanic, also mechanic who does suspension alignment, they are all looking at the problem but no-one has a definite answer. I feel like
    maybe no-one has had to change the strut assemblies before?
    I mean the shock inserts have been changed at least 3 times that I'm aware of while my son inlaw owned the VL .
    but the alignment problem still exists, cann't hurt to change the strut assemblies, which still leaves me finding undamaged struts or use struts from another model commodore if compatible, so I've come full circle, WILL strut assemblies from another model commodore fit and be compatible with the VL ?????
  15. #15
    VL Executive
    Jun 2006
    Mudgee NSW
    Unhappy
    I still live in hope some-one has a magical answer, maybe I should ask whether anyone in a diferent model commodore VB-VK and used VL struts and if they were compatible.
  16. #16
    VL Berlina S2
    Jun 2006
    anything from a VB VC VH or VL i know will be the same strut. VN - VP i think are the same but couldnt be 100%.
    should be able to pick up a decent secondhand pair pretty easy. Also is the car lowered?? if so how? if the springs were cut then that would actually be your most likely problem so replace them. Good idea to replace the strut tops with Nolathine ones (red) whilst you have em out (if it doesnt have em already).
    could be so many things causing your alignment problem though, could be Z bar bushes, sway bar bushes (or the swaybar itself), ball joints, worn steering rack, worn tie rod ends etc etc etc....best to get it fully checked out by a suspension specialist or mechanical workshop.
    cheers
    retro tech HX project on the go....
  17. #17
    calais_hero Guest
    i dunno if this would work but yeah, i took the whole strut assembly out of vn commodore and placed then in my vk as i couldnt replace just the shock so it should work have alook at the suspension and see if it looks the same as another old skool commo.
  18. #18
    VL Executive
    Jun 2006
    Mudgee NSW
    Thumbs up
    Quote Originally Posted by abcent
    cheers
    Cheers Abcent, best news I've had all day, son inlaw & his mates cut rear springs to lower the rear, I did not even consider that the front may be lowered, maybe that why shocks have been replaced so many times, maybe bottoming out and a good way to bend shock shafts, steering rack [ not bad but] is being replaced in next few weeks as will tie rods, you refer to the strut tops with Nolathine, excuse my ignorance is that the same as the bearing assembly plate or are they just stops to prevent shocks from bottoming out.
  19. #19
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    VN struts will definately fit. Sorry for the late reply but have been working. Just go to a wreckers and ask for VL or VN struts as they are exactly the same. Just like the VL V8 and turbo brake discs are the same as the VN too.
  20. #20
    VL Executive
    Jun 2006
    Mudgee NSW
    Quote Originally Posted by calais_hero
    Cheers Calais_hero, thanks for your input things seem brighter at the moment as the strut assembly I've found in excellent condition are actually out of a VK but before handing out cash I would like to know if it will work inthe first place, things look promising but I'll listen to any comments offered.
  21. #21
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    Quote Originally Posted by kalais6
    yeh they have the same bolt pattern but we tried to put my stock VL 15's on a VR and they went on but they rubbed against the brakes, wheels wouldnt turn so the later hubs might be a little bigger or have a spacer or sumthing, just some warning there for ya
    *EDIT: just thinkin about that, thats earlier wheels on later model, ur doin the oppisite so u'll be ok. As i had VS rims on my vl and they were fine my bad
  22. #22
    VL Executive
    Jun 2006
    Mudgee NSW
    Quote Originally Posted by bangers
    Thanks to bangers, they say better late than never, welcomed news knowing this widens the pool to get a good set of struts, great input
  23. #23
    VL Executive
    Jun 2006
    Mudgee NSW
    Quote Originally Posted by BigDaz
    Thanks , got my eyes on a set of VP commodore CSR alloy rims with new tyres at a great price but not sure if they would fit with no problems, so if you tried VS on your VL ,,, maybe fine. cheers
  24. #24
    VL Executive
    Jun 2006
    Mudgee NSW
    cheers
    waiting on Milkman, who is wrecking a VL, maybe I see a set of struts.
  25. #25
    VL Berlina S2
    Jun 2006
    yeah the bearing plate assembly, stock ones are rubber, better ones are the Nolathane. And chances are if the front is lowered with cut springs it probably wont even have any bump stops left so might need some new ones of those too. (unsure where you'd get those though sorry).
    good luck
  1. Suspension Question
    By johnsy33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 04:03 PM
  2. Does Vl Suspension Fit Vn ?, Just one question, Thanks
    By coops_23 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2007, 08:14 PM
  3. Suspension Question
    Last Post: 05-02-2007, 05:19 PM
  4. Another suspension Question
    By evil_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2006, 05:46 PM
  5. Question on suspension
    By Rinn_P in forum General
    Last Post: 10-02-2006, 07:02 PM
