Results 1 to 18 of 18
Thread: Noise From the Brake/Tyre
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    Default Noise From the Brake/Tyre
    Can you get a wierd sort of a noise/feeling form bald front tyres??? I getting a constant sort of a rock in the wheel noise but faster and stronger. Pull my bearings out and checked them they are fine. Pull the calliper off, got rid of the rest of the dead frog that was crunched up inside, put it all back together properly and is still making the noise.
    Only seems to happen once i've been driving a little bit and she's all warmed up.
    Only sounds like it is coming from the front right wheel (the one with the frog), but both tyres are bald on the inside.
    vl berlina wagon 6cyl
    Jul 2005
    you could try putting the back tyres on the front and the fronts on the back
    the tire wear suggests you need a wheel alighnment but I dont think it would cause the noise, mnaybe front suspension wear or the steering linkages
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check the anti rattle springs on your brake pads. They might be bent from the frog being in there. Make sure they have the same tension on them as the other side that doesnt rattle
    VT
    Apr 2005
    QLD
    get new tyres and a wheel alignment....see if the noise changes from there. grab the top of your front wheel and shake the crap out of it ie. as if youre pulling it away from the car...if you feel movement, it is one of two things. wheel bearings or the nut that holds gas inserts in your struts. check that, let us know how you go, but FFS, please get some good tyres.
    stay safe
    The Maniac
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Well i got new tyres yesterday, still makes the noise when it warms up...Cant stop the wear on the inside of the tyres cuz the car is so low and cant put a camber kit in to fix it.
    The pads fit in the calliper tightly.
    Doesn't look like the discs need machining, not completely sure.
    How many sets of bearings are the in the wheels????
    Not sure about anything behind the calliper/disc something in there, took one look and just thought im not sure if i should touch.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Are you running bigger rims and tyres? the tyre could be rubbing the strut.
    ========My Statesman 20's Mafless and 3.9's========
    Apr 2006
    Mt Gambier SA
    There are two bearings in each wheel, the one closest to the strut is much larger than the outer one that you see wheen you undo the nut. You may have to pull the seal out to see the inner bearing. If your not sure about whats in the brakes just put the front up on blocks so you can compare the left side to the right. Both sides are the same.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    sound like it needs to be looked at. sucks that the car is too low to have wheels turning properly.... doesnt that tell you something?
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Car is running on 16's...It tells me that my car is too low :P It'll look like shit higher, also loose it's reputation. For the next person to fix if they have a problem, had the car for 3 years, think its time for a change. I'll get a project VL when i move out of home, Again :|.
    The tyres only rub the strut while turning with weight, or on a slight hill turn/roundabout. They guards cut the tyres with weight and full lock, or uphill u-turns.
    Where abouts is the inner bearing located? Ive replace the outer ones on both wheel already.
    Would it be possibble that having the frog in there has bent my disc? I am only thing round the brakes cuz it happens when it warms up (the Disc/Brakes).
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    i doubt in completeness that the frog would do any damage. metal expands with heat, so once your brakes are warm any warping would be more obvious.
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Jules86
    this is totally possible if the frog was made out of titanium. or 4140. if the frog was of the organic kind, then as vlv8 said, the frog would have zero impact on the brakes. discs warp due to old age, excessive heat (ie excessive heavy braking) and/or defects in the disc. brake discs are not that expensive these days, even a nice set of dba slotted rotors are around $100 a throw. you mentioned that you have changed the outer wheel bearings a while ago, why wouldnt you change the wheel bearings as a set? i think you may have your wires crossed here.....if you buy a wheel bearing set, you will get two bearings, a lip seal and in most cases, a split pin for the castellated nut on the spindle.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    sorry to get bit off topic but what is a frog?? (bsides a animal)
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Oct 2005
    LOL i just reread it to find that
    it isnt a part but was the animal type, lol i thought there was a slag name for a part called 'frog'
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  15. #15
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
  16. #16
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Quote Originally Posted by EcotecManiac
    Didn't know you could get sets, took the old one in and got replacements for both sides, got nothing but 1 lot of bearings for either side.
  17. #17
    VT
    Apr 2005
    QLD
    Yeah, for sure....nearly all parts retailers will have wheel bearing kits for your car.....all will get you out of trouble, but some bearings are better than others....timken, skf and (dont laugh) F.A.G bearings are the better of the bunch
  18. #18
    vlcommie
    Jun 2006
    brissy
    if cars shacking it will be tyres due to run out get it to a tyre shop an see what thay can do thares one way to cut run out down an that is get tyre spun 180 on rim it might work
  1. VY S pac Tyre noise
    By red\/Y in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-04-2009, 06:14 AM
  2. tyre noise
    By BUSTER1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2007, 05:11 PM
  3. Tyre Noise --- Plz help
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 09:10 PM
  4. Wheel bearing or tyre noise?
    By Nuffy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 03:14 PM
  5. Rear Brake Noise -- HELP --
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2005, 11:16 AM
