Results 1 to 6 of 6
Thread: blowing fuses
    thestash_16 Guest
    Default blowing fuses
    hey, ive just come across a very bad problem with my vl. my low beam and high beam fuses blow every time on turn on the lights, so for the past week ive been driving home in the dark. i use 30A fuses, and the standar 12V, 30A relay. befor they were working fine, but then just one night, they started blowing up! any idea what may be causing this?
    VT SS S2 A4
    Aug 2005
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    shorting out some where or bad earth, might be in the idercator stalk as mine did it b4 jsut got a second hand 1, and problem fixed but i recomend if ur not conferdnt in doing it ur self or finding it go to a auto elec as u dont wanna fiddle with teh cables and set the car alight or do damege to the ecu
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Cozza88 Guest
    i had the same problem mate, check that the rear bulbs are 2 stage bulbs in ur brake lights.. u will know which ones need 2 stage bulbs coz inside where the bulb goes in it has 2 metal strips instead of one and on the bulb there should be 2 little limps on the end that goes into the light holder.. if it has one lump on the globe, and its in a 2 stage fitting, it will blow every time coz its shorting it out and sending a current back to the fuse.. all up there should be 4 of the 2 stage bulbs and the rest are 1 stage bulbs (1 stage bulbs only have 1 lump on the metal end) ....
    Mar 2006
    Mine Used To Do The Same. Took It To Auto Sparky Who Said Its Pretty Common On Some Commies.he Fitted An In-line Circuit Breaker...prob Gone Good Luck
    broadtail is offline broadtail
    VL Executive
    Jun 2006
    Mudgee NSW
    Quote Originally Posted by groucho
    same problem, same fix an in-line circuit breaker fitted by auto sparky cured my problem as well. cheers
  1. wk blowing fuses
    By caprice123 in forum Electrical Wiring / Questions
    Last Post: 23-12-2006, 09:09 PM
  2. blowing fuses
    By lurkin308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 10:12 PM
  3. Blowing fuses
    By spice_man2069 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-08-2006, 08:52 AM
  4. Fuses Blowing
    By jamiekratin in forum Car Audio
    Last Post: 24-03-2006, 05:37 PM
  5. Amp Keeps blowing Fuses
    By Darkwander in forum Car Audio
    Last Post: 26-02-2005, 10:26 AM
