Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: diff ratios
    vk commodore
    Apr 2006
    Default diff ratios
    can anyone help me out. im wondering wat the diff ratios r in a 6 cyl auto vl and a 6 cyl manual vl. do all vls have disc rear brakes. Cheers
    vl berlina,vl nothing,vt v8 ex police
    Aug 2005
    perth WA
    I think they are a 3.45.1 standard,only calias has disc rear unless it was a option when new
    vk commodore
    Apr 2006
    so manuals n autos have the same ratio do they? So there r vls with drum brakes?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    yes autos and manual NA rb30s have the same diff ratio. mainly turbos and V8s had disc rear ends.
    1991 Vn s2
    Feb 2005
    Warracknabeal
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    you might find that diff centre is out of another model commodore or even out of a ford.
    VT SS S2 A4
    Aug 2005
    1991 Vn s2
    Feb 2005
    Warracknabeal
    Quote Originally Posted by bangers
    yeah i think its a vk diff
    k§£¥
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    VT SS S2 A4
    Aug 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    VN onwards 6 cyl are 3.08. All 6 cyl vl's turbo or NA are 3.45 Borg warner. Most NA vl's out there are drum brake rear. NA 6 cyl rear disc setup uses the 25 spline 2 pinion open wheeler diff. Turbo gets 28 spline 4 pinion.
    ========My Statesman 20's Mafless and 3.9's========
    Dec 2005
    Nsw - Taree
    is the rear disc diff better than the drummy's?? coz i just changed mine to rear disc with the diff n all
    1991 Vn s2
    Feb 2005
    Warracknabeal
    Quote Originally Posted by BigDaz
    did ya have to change ya booster?
    k§£¥
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Yeah you have to swap the booster, otherwise the rear discs always stay on a little due to the drums needing a constant higher PSI than the discs do.
  15. #15
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by ucwepn
    you mean change the master cyl..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  16. #16
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Thats the one LOL cheers haha
    I'm gonna do this conversion before the end of the year hopefully, just gotta find a disc brake rear on the right side of $300 LOL
  17. #17
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    cant u use the same master cylinder but u have to remove a valve in the cylinder?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  18. #18
    Dec 2005
    Nsw - Taree
    they dont feel like they are stayin on, i didnt change the master cyl .... any1 done the conversion or u guys just talkin up like i've found alot of ppl do around here ......
  19. #19
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Well I've done a bit of studying in this area LOL, The info I found for the disc brake rear conversions being done on VL's was that there is a PSI difference between the master cylinders because the drums are using the extra psi to keep the shoes open because they are spring loaded. And that if you use the drum master cylinder on a disc brake rear conversion you will get a small amount of brake drag because the pad will be touching the disc. Calais turbo are the best for VL tech articles, I swear by the guys there.
    There are dreamers on every type of forum on the net, its just human nature rofl
  20. #20
    Dec 2005
    Nsw - Taree
    lol yeh tru. I try and stay clear of CalaisTurbo if i can, man some of those guys like an argument!
  21. #21
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by kasey375
    ive got a 3.36 in my vl turbo
    Whats the reason for the 3.36 diff ratio? Wouldnt you prefer the 3.45 VL ratio instead, and the Borg Warner diff is stronger than the big salisbury diffs?
  22. #22
    vk commodore
    Apr 2006
  23. #23
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by rb26dett
    v8 was 3.08, 6's were 3.45
    and VL turbo was 3.5.1
    Cheers.
    * RVN 355 *
  24. #24
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by subdue
    No VL Turbo's had the 3.45 ratio also. Same diff as the VL V8 (4 pinion, 28 spline), but with the 3.45 ratio.
  25. #25
    Dec 2005
    Nsw - Taree
    ^^^ thats right too, i read it in the gregory manual
  1. Diff ratios
    By damianison in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-08-2006, 02:16 PM
  2. Diff Ratios VS V8
    By Mike Anda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2006, 01:44 PM
  3. Diff ratios ?
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2006, 11:10 AM
  4. diff ratios
    By atreyu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2005, 07:19 PM
  5. Diff Ratios!
    By Gigs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:39 PM
