Results 1 to 13 of 13
Thread: vl turbo help misfiring
    STYALR Guest
    Default vl turbo help misfiring
    Hi im having a problem ive just been to the mechanics they said i have sum leaks in the cooler piping & maybe the AFM
    my car is playing up sumtimes idles really LOW like 400 wen im sitting at lights and sumtimes idles ok, and i can be cruising 60kmh then put my foot down and it kinda backfires sounds like a WRX or sumfing boop boop and shudders back and forward kinda like im missing a cylinder?
    Could this be my SPARK plugs/ Ignition leads or a mate told me its my CAS but the mechanics had my car for 2 hrs and im sure they wud have told me if it were the CAS
    ANY HELP APPRECIATED the car i have is a vl berlina turbo
    VT SS S2 A4
    Aug 2005
    STYALR Guest
    yeah sum kinda leak in the cooler piping or sumthing he said, for sum reason im leaning towards spark plugs and ignition leads :S wat u rekon? & wat leads and spark plugs wud u reccomend for a turbo?
    VT SS S2 A4
    Aug 2005
    Cooler piping leak will do it.
    I have 10mm Top Gun leads and NGK spark plugs.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'm leaning for a leak in the piping too, if thats what he reckons then its worth having a look, check all your joins and just make sure theres no cracks etc.
    VT SS S2 A4
    Aug 2005
    VL Calais Turbo
    Nov 2005
    get a can of aerostart it works great spray it on ya pipnin and fittings and if there is a leak the revs will pick up mine did the same thing i got a turbo too and it worked great
    STYALR Guest
    Quote Originally Posted by rb26dett
    Is your car going thru alot of fuel too?
    yeah it goes thru a bit of petrol and to the other question there are no cracks in the piping which is good
    warney's Avatar
    warney is offline did you say bukakki party
    VL skid car what else are they built to do
    Mar 2005
    just sell it to me ...i will take it off ya hands! :P
    ontopic : try ya leads though if the piping aint shitty!
    STYALR Guest
    the thing that still has me puzzled is that it only does it wen the car is at normal operating TEMP like u can drive it for say 15 - 20mins its fine THEN my OIL PRESSURE drops really low and then it starts 2 shudder, rough idle at the lights etc and misfire
    last nite i was driving i pulled over a few times and it starts up again straight away 1st turn of the key even wen its still runnin shit so i think i can EXCLUDE the CAS cos if it were the CAS it wudnt start 1st time
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the points on teh inside of your dizzy cap? u checkd them as mine was doing that run fine till it got 2 normal operation temp then when it got there kept missfiring , i just sanded the points clean and prob solved
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Bax
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by STYALR
    My car was still starting fine when the CAS was playing up. Sounds like yours was doing exactly the same as what mine was aswell.
    broadtail is offline broadtail
    VL Executive
    Jun 2006
    Mudgee NSW
    I would still check your CAS, it will still start , just not read the signals correctly, and send those incorrect signals to the cars ECU [ cars computer] causing firing problems.
  1. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  2. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  3. misfiring..
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-07-2006, 11:24 PM
  4. misfiring....
    Last Post: 29-04-2006, 06:06 PM
  5. Am I misfiring? please help!
    By ssn8r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 09:54 AM
