my fan behind my radiator is really noisey,
its in good condition it just it makes a lot of air being blowen around noise like gushing air, and i wasnt sure if this was normal, is there anything that can be done to quiten it down? or is it one of those things i should just try and ignore and turn the music up a bit more
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
if its annoying this piss out of you like mine does.....it's safe for me to assume you have a/c., as I was told that non a/c VL's dont make asmuch noise?????
Dont care.....everything works properly......??????
yah everythings fine, and yep i have the good old hot air blowing a/c, needs gassing
what about metal fans would they make less noise????
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
I can not speak for holden fans but before the VL I've been Ford only, one eyed even, but the metal fans were even more annoying and I would have thought it would be the same with holdens but I haven't tried it on the VL so I'm only going on past experience. cheersOriginally Posted by VL Berlina 5speed
When the car has been driven turn it off and see if the fan spins by hand easy, if not the fan clutch hub might be stuffed..Originally Posted by VL Berlina 5speed
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
nah it dosnt. i get about half a turn to 3/4, so dose taht mean it stuffed,
note its the nosie of like air getting blowen around no wierd scratching or scrubing nosie like worn bearings
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Some lock up and some free spin when stuffed.Originally Posted by VL Berlina 5speed
Try opening the bonnet start the car and from under the bonnet open the throttle slowly till the revs are about 1700-2000rpm and the fan should be roaring air in , hold the revs there say a minute and the engine should all of a sudden gets real smooth and the air roaring in should stop. If it does that it's ok , if it roars non stop it's stuffed..
And look under posts of CLUTCH FAN as people have commented b4..Originally Posted by mag
