Results 1 to 7 of 7
Thread: Low oil pressure after 10mins of driving
    STYALR Guest
    Default Low oil pressure after 10mins of driving
    Hi guys i need some help again on a problem im getting 'low oil pressure' after a 10min drive or so.
    When i start the car oil pressure goes up to where it shud b past half way its fine then when ive been driving for a bit it seems 2 drop and when it drops thats when the car plays up, misfires, idles really bad and feels like it wants 2 stall.
    B4 all that she runs good wiv all the power in the world only until the oil pressure drops she clowns around on me.
    Wud this have anything 2 do wiv the 'oil pump'? or sumfing else CAS even?. i have changed leads, sparks etc..
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    worn big ends would be the likely problem. once the oil heats up and thins, the worn big ends causes less oil to get to the top of the motor. just a thought anyway.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by bangers
    Yeah I was about to say the same thing, engine hammered
    My oil pressure is max on the gauge when cold and only goes toward low when hot at idle, while driving not below half..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    STYALR Guest
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by mag
    what is it ment to be at when cold and hot, as mine is always at max when the engine is running, i thought it was normal and when it moves its bit off a prob
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Mar 2006
    Thumbs up Oil pressure problem
    Could be two probs .Don't rule out electrical or other fault at sender and/ or gauge PLUS CAS or other fault. Go to a service centre, engine reconner where they have a screw in oil pressure gauge and verify first.Even the voltage regulator or earth on dash may be dikkee.Bestaluk Groucho
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by VL Berlina 5speed
    Yours sounds like the gauge is not connected.
    It is normal to be low after it warms up.
  1. low oil pressure when hot
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-11-2006, 10:05 PM
  2. Oil pressure?
    By cohn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-09-2006, 12:41 AM
  3. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
  4. Oil pressure?
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 05:36 PM
  5. Oil Pressure
    By Terfade in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2005, 09:39 PM
