Results 1 to 8 of 8
Thread: km on speedo not working
    Apr 2006
    Default km on speedo not working
    gday ppl just bought a 88vl and the km section on speedo doesnt work. and there is a whiney noise how do i go about fixing them? it was working when i bought the car.
    2nd problem with the car is when i fully turn the steering wheel one way it makes a rubbing niose. if i dont do it fully it makes no rubbing noise. any ideas on wat is going on here?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by frankyj54
    Where is the whiney noise coming from?
    What kind of rubbing noise exactly? Most cars will make some noise at full lock...and you shouldnt use full lock away...when doing a u-turn or something when you hit full lock turn the steering wheel back a fraction so that its not at full lock. You simply should not be turning the car at full lock anyway.
    Apr 2006
    Quote Originally Posted by 1991_Vn2nV
    the whiney noise seems to b coming from the drivers side off the car.
    the rubbing noise sounds like when rubber hits metal.
    1991_Vn2nV's Avatar
    Mar 2006
    Well if the car is lowered perhaps the tyre is rubbing against the guard...I would just avoid using full lock.
    The whiney noise could be many things...I cant help without seeing the car/hearing the actual noise... but good luck finding the problem man.
    Im sure the VL guys will have a few suggestions for that and the odometer when everyone is awake
    VZ
    Feb 2006
    SE.MELBOURNE
    i the rubbing noise might be ur brakes..so i suggest for u to get ur brakes checked.
    Dragz.
    vl berlina wagon 6cyl
    Jul 2005
    the distance recorder problem is mentioned as a common problem, I dont know how its fixed, some say to question the distance reading on any VL as the recording part has probably broken in the past
    look at the front tyres for any rubbing marks
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    yah the whining nosie could be the power steering under pressure when u got it at full lock and hold it there, as said b4 you should neva hold it at full lock hold it a fraction of full lock
    and the odo/trip mine was doing that, so i took it apart and gave it a good blow out and it seamed to fix it fine
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL BT1...VL Group A SS
    Mar 2006
    Simply remove your cluster and send to an instrument specialist. They'll give it a going over, replace damaged cogs and check for speedo accuracy etc.
  1. speedo not working
    By clyde in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:07 PM
  2. speedo not working
    By winton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 10:47 PM
  3. speedo not working
    By MiSs MeOw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2007, 01:17 PM
  4. Working out speedo corrections....
    By NORTI in forum General
    Last Post: 26-02-2007, 10:22 AM
  5. Speedo not working
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 11:01 PM
