Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Thread: VL, Holden or Nissan???
    VS Clubsport
    Jan 2006
    Default VL, Holden or Nissan???
    Do you think that a VL can really be classed as a Commodore? OR should it be reconised as a Nissan?
    After all, Imagine if they replaced the 5.0 litre for the VN onwards with a Toyota V8... You wouldn't class it a Commodore, surely!!! It would be like Ford replacing their 4.0 litre with a Lexus straight 6...We'd be baggin the crap out of them!
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    so should we rename all the commodores after that Buicks and Chevys???
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    just waht i was think, y dont we name the vs u drive a buick,
    because the car has a engien from a diff company dosnt mean its not holden,
    as what makes the car what it is, is the shape style apperance interor floorpan suspension etc, not just one thing makes the car what it is many parts make it
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Ravenblue Guest
    Motors make there way into all sorts of cars mate. if someone makes a good one its can end up under the bonnets of multiple manafacturers vehicles.The 3.8 is a good example of Holden transplanting an engine from Buick.
    If you got a heart transplant from a baboon would that make you a baboon??
    Grantis1976 Guest
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by Ravenblue
    Clear example America made the GEN III holdens worked it and send it back badged as a Pontiac GTO work that one out....?
    Izuzu make the Rodeo and classed as a Holden Rodeo
    Even Opel,vaxhual Vectra is A Holden.... weird isn't it.
    Clearly the Vl was in a big need of something different from Holden. In the 80's the 202 just wouldn't cut it for a 1986 model car so what were Holdens to do when there 3.8L buick was still in the new manufacturing and engineering stage for the VN New Model Commodore !.
    Cheers.
    * RVN 355 *
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    They are all sharing the parent company of GM. One big family of cars that interchage parts. Anything would be an improvment on the rubbish Ford au put out. Lexus would actually make them a good car
    The V6 in the VN + cars are olny buick based. They had a lot of different stuff in them, they were not just imported transplants like LS1 and LS2 are.
    They were designed off the buick platform and built to their own specs here in australia.
    I think that the early V6's at least were a pale comparison to the buick version anyway.
    Opel in europe were the inspiration for the early commodore body shape. They where almost identicle to look at. Do a google for "Opel Senator 1983".
    Kain
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    the holden v6's were pretty much bit for bit the same as a american buick LN3 v6. the main difference was the elbow and bigger throttlebody as most american ones were in FWD cars, so were east west placement and had space for a long tb neck. if kept the same, it would hit the firewall.
    brackets are all the same, alternator is same, exhaust manifolds are obviously different for rwd application. few minor changes, but the majority of the motor was the same thing.
    then the americans made the L27, which was pretty much a vn series 2/vp motor, but that had a different intake manifold while we retained the series 1 unit. they also got some crazy egr crap bolted to it, while we were lucky to keep our ecu controlled egr setup.
    then they went to their series 3, which is what the ecotec is based on, but the intake manifold again are different to the american one.
    etc, etc.
    VP Executive R-spec
    Jan 2005
    You wont find many difference in the motor in VN compared to a Pontiac, Inlet manifold/Throttle/Exhaust that's about it. They got here on a boat just like the gen III, made in the USA
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    The only reason that the exhaust and intake is different on the Holdens compared to, Chevy, GMC, Buick, Oldsmobile and Saturn is due to the fact that they were used in FWD cars. Not rear wheel.
    I'm hoping that people will soon realise that the 3.8 is NOT a Buick engine. Infact it is a GM motor which owns Buick and the motor is used across the board in all platforms. INCLUDING Cadillacs that are not using the Northstar V8
    The 3.8 motor also comes in a 3.1 and a 3.4 size.
    Trust me, look through the different cars released with Buick Badge on them....you don't want to own one of them! Let alone associate your own car with one.
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    Quote Originally Posted by 12Voltking
    After this enlightenment maybe more people will realise the V8s are not just Chevy engines either. Doubt it though as it is a sore point for some.
    My car, well it's just confused: Badged Toyota, put together by Holden and powered by an American GM motor.
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    Tasmaniak's Avatar
    car
    Apr 2005
    Quote Originally Posted by Pretender
    Oh god no! Once again!, Chevy, GMC, Buick, Oldsmobile Pontiac and Saturn
    I also noticed that I forgot to put that the 3.8 is also used in Pontiacs.
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    We won't get into from where some of the parts are sourced for assembly in the USA. That will just make people cry.
    Never
    VRFURY's Avatar
    VRFURY is offline Just Nic
    VR Caprice
    Jun 2005
    Warragul
    personally i hate it it when people talk about this topic because ive had so many people on this forum tell me im not a true holden supporter just because i have a vl which has a nissan motor. It really pisses me off cause clearly i dont agree with em.
    I think VL's came out with one of the sexiest commodore shapes. But thats my opinion, and yeah i really dont like it when people say its not a holden.
    Behind every Great chick, Is a guy checkin' her out
  15. #15
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Quote Originally Posted by vlfury
    You most certainly own a Holden so do I but it's badged as a Toyota.
    We Lexcen owners cop a lot from others as well.
    If we used the logic of the VL argument then there are no Holdens currently produced apart from the cars which are assembled overseas that use the Family II engine
    This of course means that the Daewoo Nubira is a Holden and a Commodre is not.
    Never
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by VSCLUBBIE
    Yeah it's a Holden. An engine/box combo isn't a car. Using your logic countless thousands of Pulsars and Saabs are Holden because they run a family II engine. Is the VN-VY a Buick (or Corvette)??
    Most cars are a big conglomeration of bought in parts that are assembled by the manufacturer. The VL was assembled by Holden and is no different to any other car.
    Reaper
  17. #17
    Reaper's Avatar
    Aug 2004
    Fair comment. IMHO the Ser 1 VN motor was very symptomatic of what it was - a rough as guts rush job to get the car on the production line. They did get a lot better in the Ser II onwards.
    In my experience the VP - VR and ecotec motors have proven exceptionally reliable with the bodies of the cars more often wearing out well before the engines do. This is a big step when you cast your mind back 10-15 years before that when a reco engine was routine about 1/2 way thru the cars life.
    Reaper
  18. #18
    Tasmaniak's Avatar
    car
    Apr 2005
    Reaper, I never mentioned about the quality of the motor. I was simply pointing out that it isn't a Buick motor.
  19. #19
    Girl Torque's Avatar
    Girl Torque is offline VL Calais 5L
    VL Calais.. etc
    Sep 2005
    SA
  20. #20
    VT SS S2 A4
    Aug 2005
  21. #21
    Jan 2006
    All VLs are Holdens, whether they're powered by Nissan or not.
    Whether people don't want to call them Holdens, is their own opinion, but the fact still remains, that on the rego, it's says Holden.
    VLs always cop shit, from both sides.
    I think the people who say that VLs are only good/quick, because they have a Nissan engine, are very ignorant.
    If that was the case, then there would be no need for a gearbox, driveshaft, diff, tires, brakes etc.
    The engine by itself, doesn't make a car, what it is.
  22. #22
    Tasmaniak's Avatar
    car
    Apr 2005
    That doesn't make sense. She owns a car that is badged Holden but powered by nissan. So that makes her car a Holden correct? Yet your car is badged Toyota but powered by GM. So how does that make it a Holden?
    I feel a flaming coming on here
  23. #23
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    lol end of topic vl is a Holden allways has been allways will be if ur gonna start on things like this shit because it has something from another car can u really say that half the new holdens are really holdens if there bassed on the korean or wotever shit they got it from.
    [SIGPIC][/SIGPIC]
  24. #24
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    LOL, love that comment.
    Honestly does it really matter, if the other Commo owners are giving you a hard time just call their cars opels and be done with it.
    As long as Holden dosn't turn the Commodore into a FWD drive car I'll be happy.
  25. #25
    Grantis1976 Guest
    Its what u want it to be !!!
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. Gas Turbine Nissan Vid
    By Lexx in forum General
    Last Post: 17-08-2005, 08:08 PM
  3. 1989 Nissan exa
    By patrix in forum General
    Last Post: 09-07-2005, 09:59 PM
  4. nissan 720 ute
    By shane0o7 in forum Parts And Other Items For Sale
    Last Post: 12-09-2004, 10:33 PM
