Results 1 to 12 of 12
Thread: Boot Leaking
    1988 VL Executive
    Jul 2006
    Default Boot Leaking
    Hello All,
    Just a question... My VL boot is leaking. Eg. When it rains, puddles form in the front of the boot. Is this a common problem, and how do I fix it?
    Thanks for your help.
    VRFURY's Avatar
    VRFURY is offline Just Nic
    VR Caprice
    Jun 2005
    Warragul
    i had this problem, but mine was from when it got resprayed the guy didnt seal my tail lights so the water was running straight down the back of the and into my boot. Mine was easy fixed by putting silocine in and around the top of my lights
    Also you could check the rubber that runs along the top of the boot, i resealed ,mine cause it looked a bit dodgy
    Behind every Great chick, Is a guy checkin' her out
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    i wouldnt recomend using silicone as it attracts moisture and can cause rust.First thing id do is make sure all the rubbers seal properlyt and are in good condition then check all the gaps
    [SIGPIC][/SIGPIC]
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    If you want to find where a leak is coming from just hop in the boot with a torch and get somebody to spray water onto the boot. You shoud then be able to see if its a rust issue or an old seal
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    CALAIS 6's Avatar
    Aug 2005
    lol thasta different approach but that would also work well lol
    [SIGPIC][/SIGPIC]
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by Gunnolf
    yep thats how u do it, and pull the rubber seal of teh boot it is common for the whole lip to be rusted away and allow water in.
    the corners of the back window is the other prime spot, water gets under the rubber and runns onto the parcel shelf then drips down thought the rear seat belt retractors causing them to seize up and then gets in ur boot
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    executive vt 5.0lt
    Feb 2005
    west suburbs
    1988 VL Executive
    Jul 2006
    I don't have any rust in the boot as yet. Where would I take my car to get it fixed?
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    Quote Originally Posted by Lozzza
    well if there's no rust and you just need the seal replaced then it's a pretty simple job to do yourself at home.
    1988 VL Executive
    Jul 2006
    thanks for ur advice. i went to a local smash repairers. they cheked it out and there was no seal over my right tail light. they sealed it then hopped in the boot and sprayed water over it. water was still coming in. then pulled up the seal and found acouple of rust holes. they sealed it up. was a cheap job for me... $25!
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    If anyone needs some of that fish oil stuff in the spray cans; they got big cans for sale for $5 bucks at Big W Macarthur Square Western Sydney.
    They have rearranged the shelves and stuff and put the paint up cheap as they got no where to put it. They even have wierd colour, epoxy paint for ya engine at five bucks.
    best wishes from holdy
    VE & VL
    Jan 2005
    As of today 24 Nov 2006 those same cans of Fish Oil have been reduced to $3 each.
  1. Boot leaking? Wah!!
    By Heffer_Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2011, 06:40 AM
  2. boot leaking
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 05:50 PM
  3. boot leaking
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 04:40 PM
  4. VK Boot leaking
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 02:50 PM
  5. Leaking Boot - Revisited
    By chicane_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2006, 06:41 PM
