Page 1 of 3 123 LastLast
Results 1 to 25 of 67
Thread: misfiring..
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Angry misfiring..
    well this is really peeing me off, car is running like shit!!!
    same symptoms as b4, fine till gets to op temp then missfires at 1000 to 1500rpm
    ive done all i can to find what is causing it and its not going away
    replaced/fixed:
    - new dissy cap
    - 6 new spark plugs
    - new rotory button
    - removed the whole dissy unit, checked over it, no orange powder, replaced the 'o' ring with new 1
    -fitted a new CAS plug
    -replaced temp sensor
    -set timing with ear, to best possible
    - used timing, gun no beta
    -checkd all my high tension leads seam to be fine
    -checkd at nite for arcing in any of teh leads or plugs
    -new fuel filter
    just o2 sensor 2 replace/check, anything else that can cause it? or i missd
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Wink
    Quote Originally Posted by VL Berlina 5speed
    replaced/fixed:
    - new dissy cap
    - 6 new spark plugs
    - new rotory button
    -new fuel filter
    Those spark plug leads need to be checked with a multimeter 4 omhs reading.
    Also ur not using any coolant are you?
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Oct 2005
    Cool
    can you explan the checking of the leads to me plz,
    and for coolant 2 weeks ago i lookd at it and it was bout 2 cm below max on the tank, so topped it up with distiled and its gone bak down to 2cm below full,
    so ive got my eyes on this as it could mean heads gaskets gone or heads almost there,
    but its strange last week it was fine then all a sudden it happens, then it will most likly stop and then happen again
    it was fine last night and this morning, then 2day i changed the dissy cap to a new one and new plugs and a new rotoary button, ran fine then left it went out hour later and it was missfiring... so might check over all that tomorrow and then check if did miss something
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Oct 2005
    just checkd the leads witha muilty meater
    and got,
    tested it on 2000K ohm setting
    lead number........ohms
    ....1....................002
    ....2....................004
    ....3....................004
    ....4....................004
    ....5....................004
    ....6....................004
    coil cable.... oo6
    would the lead number 1 be causing any major probs or the coil cable
    and i checkd teh Afm and its at 251, so might put my old 1 on as that has the cap on the screw punched out then adjust
    i also did a check on the ecu and nothing came up besides the usall, air con nutral, speed and start system,
    just waiting for the extracors too cool off so i can see if teh O2 sensors clean and fine
    any ideas would be very grateful,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Oct 2005
    well i think defeat has hit me and money getting givin to some1 is a have to now
    try some diffrent leads but nothing,(cheers 4 that clint too)
    chuckd my old afm on and just wroser, now it wont runn well at all, sits at 500rpm and misfiring like hell
    dam now looks like the suspension money will have to go
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jun 2005
    South OZ Adelaide
    Unhappy
    and got,
    coil cable.... oo6
    The leads reading sounds good but the coil lead being the shortest lead shouldn't have the highest reading!! I think it's still ok though..
    The coolant level droping hmm could be a pin hole in the head spraying a tiny amount of coolant in a cylinder causing it to run a bit ruff, but AMf it sounds like.
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by mag
    Ah you put that in while I was writing.lol
    anyway try this to check if it's a head prob, with a cool radiator take off the rad cap and put it back on to only the 1st stop where the cap can wobble about but can't come off.
    Drive the car like normal and if the miss is gone it's a leak in the head..
    Oct 2005
    i got one more trick up my sleave, because when i took the dissy of to check out the cas it didnt mark it the best and getting it back in was a guess job,
    hope that isnt it,
    goign to take teh top timing belt cover of 2morrow turn the motor over till its at tdc and see if the timing belt is rught and lined up
    then ill try the coolant cap thing,
    is there any additive i could add liketeh stop leak blocks to help stop the pin hole leak if there is 1?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jun 2005
    South OZ Adelaide
    hope that isnt it,
    I'd try the rad cap 1st as it's the easy...
    And if it's a leak u can use chemi-weld..
    Oct 2005
    and if dosnt turn out 2 b the head could doing that cause some probs 2 teh head?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Shouldn't case any probs but I'd check the cap thing 1st as there won't be any pressure in the rad when u try so it will tell if it's a leak.
    Oct 2005
    well when the enige is hot the pipe is very firm, and when cold its easy to sqeeze, that mean much?
    the thing i think causing the water in teh over flow 2 drop back to the same place is that im using distide water so it gets hot and evaporate, then its just left with teh coolant as was b4 and stops at the same level, could this b right?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jun 2005
    South OZ Adelaide
    Thumbs up
    ok top hose when hot should be rock hard and soft when cold that's because the pressure builds when hot and goes when cold that normal..
    And u should be using coolant not distilled water..
    Oct 2005
    i didnt have any coolant, so use some distilled, liek just to top up the overflow bottle, would that evaporate thus goign back down?
    note: i havnt fixed the oil sensor prob with the guage not moving, just keeping u informed like u askd :P
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  15. #15
    Jun 2005
    South OZ Adelaide
    Thumbs up
    no that wouldn't do it.
  16. #16
    Oct 2005
    well once i get the car to acutally run ill try the cap trick
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  17. #17
    Jun 2005
    South OZ Adelaide
    no probs..
  18. #18
    Oct 2005
    well jsut stopd playing with my car and its still fekd, cant gert it 2 idel fine, adn didnt get to try the readiator trick coz i couldnt get up the drive as it was missing that bad,
    was playin with the acc valve, i have a question is it ment to be two peice, like the centre cylinder sensor pull out of the body of the sensor as mine dose???
    and the CAS how hard is it to take it appart? dose the whole dizzy have 2 come out, and is it really figgerty? as think of getting a s/h one from teh wreakers and trying that out 2 just see if it is that,
    also checkd the ecu for lose wires and brock cables but none vissble, im starting to get vvery thin on ideas
    help me
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  19. #19
    Jun 2005
    South OZ Adelaide
    help me
    It was fine when cold u said and started to run ruff when it got hot??
  20. #20
    Oct 2005
    yep, but now its seams to be doing it at cold now 2
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  21. #21
    Oct 2005
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  22. #22
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    if you are going to pull the dizzy out make sure you turn the engine to TDC
  23. #23
    Oct 2005
    yah i learnt the hard way last time it was out, could the dissy being one groove off cause it not being able to be tuned in right?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  24. #24
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Yes it could be a groove out, but did u put a timing light on it after..
    And if it was out a bit u car would be a slug or it would ping alot...
  25. #25
    Oct 2005
    yep i had that prob when i took it out
    very touchy to get to idle nice, it was a bitch and the timing light was used but it was easyer to tune it by ear,
    so do you reackon it could be the dissy off by a groove?
    and if u think it is how do i fix it again?
    is it :
    -take rocker cover off
    -turn motor till the inlet valve on first pistion is closed
    -then turn motor over till you hit nearst TDC
    -then place dissy back in
    that right?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. misfiring?
    By vt_nutta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:34 PM
  2. misfiring
    By ciro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 09:02 PM
  3. misfiring?
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2006, 09:20 PM
  4. misfiring
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2006, 11:36 AM
  5. misfiring....
    Last Post: 29-04-2006, 06:06 PM
