Results 1 to 5 of 5
Thread: Running Rich
    VX S II
    Jun 2006
    Default Running Rich
    Just wondering if anyone else has had this problem. My mate's VL is all of a sudden running rich. What could be causing this? Cheers
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    afm might of craped it self, get a muilty meter and check it to see if its 382ohms, the o2 sensor or temp sensor could be stuffd as well as these three things all cause vls to run rich or lean,
    check the afm first,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The vaccum hose could have fallen off the fuel pressure regulator which will make the fuel pressure higher than usual
    VX S II
    Jun 2006
    Quote Originally Posted by VL Berlina 5speed
    Thanks mate. Will post later the results.....
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    could be a stuffed lead or plug. start simple first. mine was running rich and a lead had welded itself to the dizzy cap.
  1. VR running rich
    By Grivation in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2008, 04:08 PM
  2. VN running very rich
    By 333 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 06:42 AM
  3. Running very rich
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2006, 08:10 AM
  4. Vr V6 Running Rich?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 07:43 PM
  5. Running rich?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-09-2005, 07:05 PM
