Results 1 to 7 of 7
Thread: whining noise when ignition on
    vl berlina wagon 6cyl
    Jul 2005
    Default whining noise when ignition on
    was trying to start a VL 6 and got a loud whining noise from somewhere under the dash when the ign was turned on but it stopped when the starter motor was cranking
    it wasnt from the engine compartment and it wasnt the fuel pumps
    any suggestions?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    what side of the dash?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VS Commodore Acclaim
    Jan 2006
    Quote Originally Posted by harry3
    any suggestions?
    Probably a cat under the dash and when you operate the starter it scares the c**p out of it and it shuts up. Well you did ask for any suggestions.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Sounds like the fuel system priming to me. does it stop after 5 seconds without starting the car just leaving it "on".
    I have not heard of vl dash's making any kind of noise but the VK calais "starwars" dash would beep ya to death.
    I will check the manual later to see if there is any kind of buzzer warning or something like that in VL's.
    ========My Statesman 20's Mafless and 3.9's========
    Jan 2006
    any suggestions?
    It might be an instrument voltage stablizer oscilating and when the engine starter is operated the battery voltage falls so it nolonger has to reduce the 12volts to that of instrument requirement usually 10volts. As soon as the engine starts the voltage is much higher so the oscilation frequency is changed or other noises mask the oscilation. Just a theory mind and it depends on there being a voltage stabilizer on this model and if it works on the bimetal principle.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by Don Sutton
    i think i speak for everyone when i say "HUH?"
    Marco-EFIVL's Avatar
    Marco-EFIVL is offline Now driving R34 GT-T taxi
    Nissan Skyline, R34 GT-T (RB25DET NEO) sedan
    Aug 2005
    Perth Balcatta/Hyden (Wave Rock)
    Indeed.... :\
  1. loud whining noise
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-07-2006, 10:12 AM
  2. Whining Noise
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2006, 08:56 PM
  3. Whining noise - Fuel Pump?
    By Struma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 11:07 AM
  4. whining noise, plz help!!
    By macdaddy in forum Car Audio
    Last Post: 02-09-2005, 11:43 AM
  5. Whining Noise
    By syth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2005, 01:25 PM
