I let my car idle for 10min and when i take off it blow a puff of smoke. It only does it after idling for a while.Whats wrong with it?
Sounds like valve guide seals..Originally Posted by minimefx
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
mag on the money valve seal
your at $30 for a set of 12
plus a couple a hundred to have it done
unless you do it yourself
whith a compressor and the engine at tdc of each cylender
this will hold the valves up while you remove the retaining clips/springs
and replace rubber sleves this will save money and nowing the satisfaction of doing it yourself
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
sweet thank for that guys i will have a go at fixing on the weekend
I ouldnt leave an engine idling for that long, especially from cold
when blowing smoke. always suspect an overfull sump, drain it and measure what comes out, its been known for the wrong dipstick to be fitted, or the dipstick to break, giving a false reading
