Results 1 to 9 of 9
Thread: VL aircon vacuum tube matchup. HELP!!!
    dibly1980 Guest
    Default VL aircon vacuum tube matchup. HELP!!!
    Ive had to replace the aircon control panel and the tape that numbers the tubes is gone. I pulled it out in haste and because its so tight in there i dont remember which goes where. Can anyone help? I need to match the tubes to the right holes....
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    executive vt 5.0lt
    Feb 2005
    west suburbs
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by dibly1980
    If anyone has a genuine holden workshop manuel, it's in there..
    The hoses are colour stiped or numbered can't remember..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    executive vt 5.0lt
    Feb 2005
    west suburbs
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    yah they have numbers on tags that are stuck on, but after time they come off,
    if you can, go 2 a wreakers with a pen and write down what gose to where, its the only logical way i can think beside paying some1 to do it
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by carcrazy
    Since everybody wants to know this here it is
    Number three (3) Goes into the recirculation valve right near the blower fan.
    Number four (4) Goes through the firewall and connects to the engine (Vac supply)
    Number five (5) Goes to a small one way valve (White and black round thing) on the drivers side near the firewall and disapears behind the heater box.
    Number eight (8) goes to a actuator near the steering coloum with a rod and a lever on it, its close to the front of the dash and i think the lever pushes down.
    Number nine (9) goes to a actuator behind the ciggie lighter area.
    Everything else has a rubber blocking teet on it, all up i think there was four.
    Ill put this in technical for future reference by others too.....
    Courtesy of Calaisturbo.com.au
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by Bax
    That's the ones
    dibly1980 Guest
    Yeah "VL Berlina 5 speed" has the right idea but the problem is you cant really tell without pulling the entire dash off where each tube goes to. "Mags" right too, they have numbered tags on them but they fall of and then ur screwed. How much did they charge you to fix it "gungazza"? Thanks heaps for your help fellas. Im a new forum member and you guys have some good info to help out beginners. Keep it up cheers
  1. what is this tiny tube for in a V6 VS?
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2008, 04:49 PM
  2. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  3. AC Drain Tube Rework
    By hkmonaro68 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-11-2006, 06:22 AM
  4. space for tube
    By djc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 02:45 PM
  5. Air intake tube thingie....
    By rattattack1313 in forum V6 Development And Modification
    Last Post: 05-10-2005, 06:34 PM
