Yeah its farked so will be going into the workshop to check the ECU or coolant temp sensor, hopefully wont cost too much. It seems that there is sooo much pressure in the fuel system that it caused the hose after the high pressure pump to spring a leak and the car wont idle and is blowing huge clouds of black smoke. will let ya's know what it is on wednesday.
Check the plug on the amf, sounds just like what happened to my brother when he owned a VLOriginally Posted by ucwepn
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
If the return line is blocked it will set the fuel pressure sky high
It was worth a tryOriginally Posted by mag
Ok heres the story,
went to mechanics yesterday and got a reco ecu, car ran fine for 10km's then died again, went back today and got a new distributer and she is as good as gold.
Nasty old CAS was the problem lol. Had the mechanics scratching their heads for a while tho LOL
It just doesn't help that the CAS dies sooo slowwwly and the ECU won't bring up a error code until it's nearly completley dead..Originally Posted by ucwepn
hey ucwepn how much did the nasty piece of $#@ cas set u back i have exactly same problem and only worked it out when the computer brought up the error code
Well the mechanic I went to is next door to a wreckers so I got a new 2nd hand distributer for $100 fitted. They didn't charge me labour because I spent sooo much the day before on a reco ecu and the ecu was fine.
If you can't do it yourself find someone who knows all about vl's to do it for ya. don't go to a big name mechanic because it will just cost $$$$ and they couldn't tell their ass from their elbow IMO..
Oh and car is fine now, I have done around 230 km's in 2 days and all is well.
yah i was having a problem with my CAS, so i bought a second hand dissy for 88bucks and it has a 3 month warrenty, so any probs they will swap it over with a new 1![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
cool thx guys but car wont even start now is it still the cas? lmao
well its got no fuel well maybe a litre lmao it definatly has spark and compression i dunno and whats the afm? lolOriginally Posted by ucwepn
Air Flow Meter, the black sensor thing behind the air box with the cable going to it
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
yep airflow is new now its bringing up 3 of the 4 previous codes 23 24 and 31 one of em is speed sensor one idle position switch or whatever it is the other is cas so airflow meter was a prob lol now i need the cas and fuel and maybe my car will start thx heaps guys u been great help
