after recently finding out what that white sticker was by ucwepn i was intressted in what the recalls were for and after searching i finally found it,
if you have a white sticker in the front divers side door it means that your car was recalled back to holdens at some stage to repair one or more of the following faults bellow.
Problem: INSTRUMENT WIRING DAMAGED
Make: HOLDEN
Model: Commodore VL, Calais
Variant: Auto
Date Range: 1986
VIN Ranges:
Status: Inactive
Defect: 6 Cylinder models with automatic transmission only. Instrument wiring located in the centre console can be damaged by the automatic transmission selector mechanism.
Consequences: Fire risk.
Corrective action: Provide positive retention for the instrument lighting wiring harness.
Notif. Date: 10/11/1986
DOTARS No.: R86/015
Supplier Name: HOLDEN
Campaign No.: 86-H-01
Problem: POWER STEERING ASSEMBLY FAILURE
Make: HOLDEN
Variant:
Date Range: 1986-1987
VIN Ranges: L220743, L242128 J104955, J132000
Status: Inactive
Defect: Power steering assemblies supplied by James N. Kirby may have been produced with incorrect attachement of inner tie rod end housing to the steering rack.
Consequences: Inner tie rod ball joint can become detached from the steering rack, causing a reduction in steering control.
Corrective action: Inspect and replace if defective.
Notif. Date: 23/12/1986
DOTARS No.: R86/016
Campaign No.: 86-H-03
Problem: BRAKE MASTER CYLINDER FAILURE
Make: HOLDEN
Variant:
Date Range: 1987
VIN Ranges: L235800, L255100 J124000, J144000
Status: Inactive
Defect: Incorrect crimping of the joint between the front and back shells of the brake booster. Vehicles with 3.0E (non-turbo) engine are affected.
Consequences: The two shells may come apart. As the brake master cylinder is attached to and supported by the front shell, function of the master cylinder is lost.
Corrective action: Inspect crimping and replace booster if crimping found incorrect.
Notif. Date: 28/08/1987
DOTARS No.: R87/017
Campaign No.: 87-H-02
Problem: STEERING KNUCKLE CRACKS
Make: HOLDEN
Variant:
Date Range: 1987-1988
VIN Ranges: J145736, J153237 L257205, L268578
Status: Inactive
Defect: In-plant investigation revealed quench cracks in steering knuckle forgings received from ANI National Forge.
Consequences: Potential loss of steering control.
Corrective action: Inspect for cracks and, if evident, replace steering knuckle and tube assembly.
Notif. Date: 22/07/1988
DOTARS No.: R88/032
Campaign No.: 88-H-02
all the info was sourced from,
http://dynamic.dotars.gov.au/recalls/Search_results.asp
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Hey this white sticker is just white with no writing??![]()
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
nah im pritty sure it has writing on it, ill go check mine now, and see waht it says, brb
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
and the result is??Originally Posted by VL Berlina 5speed
.:Blown VT V6, DAJ37:.
Field Production Campaign
VL Commodore
And Calais
86 - H - 03
COMPLETED
Do Not Remove This Sticker
thats what mine says, so i had POWER STEERING ASSEMBLY FAILURE,
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
yea i have that same sticker on mine sean and i was just tryin 2 work out wat it was for about 40 mins ago lol cheers for that
i jsut spent 45minutes posting all the info for all the recalls made by holden in the genral chat section, so if ur wanting 2 know for other models sus that out,![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
So going by that ur car should have 2 of those recall codes as ur car was auto![]()
it might be a thing as in order, because mine is stamped as 86 - H - 03 it might mean that all faults before are recterfide, but the later ones 87-H-02 and 88-H-02 were not as they were discoverd in later yrs
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
oh interesting, thanks for posting that up.
I reckon the complete fuse box setup should have been fixed too.
Mine completely melted, lucky it didn't catch fire.
yah that is a intressing point why didnt holden do anyhting with the fuse box, suppose the fuse box prob might have only started to affect teh plastic when teh cables and the plastic rail got old in the box
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
i was just looking at that sticker on the wagon today and wondering what it was for, mine goes 86-H-01 so what does that one stand for?
it was the first recall,
Make: HOLDEN
Variant: Auto
Date Range: 1986
VIN Ranges:
Status: Inactive
DOTARS No.: R86/015
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
aha, thanks champ
mine had that too
Originally Posted by ucwepn
its from using too high wattage globes, stuff like that, it over heats it, fuse blows & then melts.
Lots & lots of VLs with melted fuserails/boxes, & few VK's too....
There is a PCB for VLs that seems to be pretty good replacement, fair sure there was a guy on the net (ebay, CT?) selling them at one stage.
D.
am i being totaly stupid to ask where the white sticker is mines a late 88 where they a prob...
Behind every Great chick, Is a guy checkin' her out
Read the post.. front drivers side door... in the door jam....Originally Posted by vlfury
if you have no sticker ur car wasnt recalled.
Some people say less talk more action, i say more torque less traction.
well mine was near my hinges on the driver's side door if this helps at all
settle justin i accidently missed where it said i cant look on my car till tonigh when it gets home any wayOriginally Posted by Infus10n
yeah about the fuse box melting, i have seen one or two in work where they have pot extra lights onto the car and bridged them off the low or high bean wires and that creates so much extra amp's to flow and the fuse cant cope with it, and neither can the wires.
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
