Results 1 to 13 of 13
Thread: VL rear disc conversion info needed
    VL Berlina S2
    Jun 2006
    Default VL rear disc conversion info needed
    I'm considering converting my VL to a disc brake rear end, going from a VK calais to drum rear VL you notice just how crap the drakes are.
    Anyone done this? know whats required?
    1: do I need a different master cylinder?
    2: can I use my drum diff an just change the brakes? or is it easier to find a disc diff an put it in?
    3: are the drum & disc diff yolks the same?
    any other extra info you might have would be much appretiated
    thanks
    Berin
    retro tech HX project on the go....
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    keep the rear end. just need hand brake cable, hubs, discs, calipers, backing plates, brake hoses, and bearings (i think). don't necessarily need bigger master cylinder but it would help.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i did the convert on my beast but i had a complete VL calais rear disc diff here so we just needed the new handbrake cable and then just bolted it all up and in. DIDNT change the master cyl, no brake rubbing at all and have since put new pads in and still no rubbing. If u can get the complete Disc diff it would prolly be easier but its up to u mate
    vr wagon, vx executive
    Jan 2005
    vn discs do bolt on with a disc brake seal kit and straightening out of bake lines and adjustment of hand brake cable. been done many times before by vl owners and me.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    the vn rear end may be a little wider (?). no problem if it is, just watch your rim offset.
    Grantis1976 Guest
    I have no idea if other brakets are needed too.
    Is the backing plate identical?????
    Is the wheelbearings different???
    Why dont brake shops do this/answer these questions???
    Who killed Kenny ?!
    If you find these out, please let me know too, after going from a VN Calais, to a VL drum bum, you do notice a big difference.
    Dec 2005
    Nsw - Taree
    VS Commodore
    Dec 2005
    Bundy
    Default V6 ecotec - vl (brake upgrade)
    Need Info on upgrading the front and rear brakes, I have a complete 95 VS COMMODORE live rear axle.
    I'm converting the engine into a VL Commodore and need to know if i can use my brakes from the VS to upgrade the VL brakes or do i need to buy a VL turbo brake package??
    and if so what is needed for the upgrade and how much?
    neo
    neo is offline
    VY_SS_Black
    Mar 2005
    hey abscent - Make live easy, get a complete VL Calais or Berlina rear disc brake diff/axle assesmbly (I got mine from a place that specialise in Toowoomba). Unbolt the old drums, bolt in the new discs. (4 bolts from memory). Be smart, and upgrade the booster and master too - don't skimp on brakes as they will save you one day!
    Apparently here in QLD you will need a Mod plate for this too - but if no one knows then.....
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    neo as long as you realise the original post was put up here nearly 3 years ago. I'd say he has it sorted by now.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by neo View Post
    Do u know how much i can expect to pay from the wreckers for this assesmbly? Or what you would pay??? Im good with haggle'n stuff cheap aslong as i know a price to work with..
    The mod plate is that done by queensland transport? a mechanic? or an engineer??
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VL 5L inj
    Sep 2007
    Woodburn, NSW
    you get the mod plate from an engineer. mine cost somewhere just under $200 for the VT front brakes, VN 5.0 eng and T700 conversion.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by Jayme View Post
    Thanks did u do the work yourself? or did the engineer?? i guess they just inspect it??
LinkBacks (?)
  1. 10-04-2008, 01:09 PM
  1. Fs: [vic] Vk Disc To Disc 3.23 Rear
    By synoptica in forum Parts And Other Items For Sale
    Last Post: 11-12-2007, 11:52 PM
  2. rear disc brake conversion infro needed
    By TURBO_VK in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2007, 07:59 PM
  3. vl disc conversion
    By rimz81 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-04-2005, 08:15 PM
  4. VLT diff or disc conversion
    By Snowfox in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-10-2004, 06:16 PM
