ok ok i finally got everything fixed on the vl as i found them one by one by the help of some of you from my previous thread so here is the new problem, i fixed everything and the car was stalling everytime theres no acceleration in stopped position and its blowing alot of black absoloute crap out the back of the exaughst so it finally has back pressure. we ran the diagnostics last night that i didnt even knew i had, anyway it came up with 4 out of the 6 possible codes a vl can come up with 21,14,23, the other one i forgot but one is crank angle sensor one is airflow and one is speed sensor the other is the idle position now the speed is false reading as car wasnt moving the airflow may need too be reset but its new and the crank angle sensor IS the problem as you all said it might be so 1 how much are they and 2 is it worthwile getting second hand one instead or is it waste of time?
don't get a 2nd hand one FFS. buy one new and get the plug for it too.
about $70 upwards. you can buy the plug separately.
i got a reco dizzy plus new cas $100 at elec auto shop
i dont see a second hand one as bad, if you are offerd a replacemnet warrnty i would take it, i was offerd three month replacemnet warrent with my dissy so i took it, and i am happy so far,Originally Posted by bangers
but when nissain is trying to charge me 235 bucks for the CAS by its self i reckon the second hand one is a good deal,
and i was told by the wreakers that the CAS will run fine for 125000ks happy then it will eventually stuff up.
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
ok 70 bucks upwards sounds good but one thing is still tearing me up and its not the weather, what does the crank angle sensor look like? and will i get those cheap prices here in queensland?Originally Posted by bangers
www.injectorsonline.com
they sell CAS for 80 bucks new, and it shows you a pic of waht ur looking at
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
its a little disc with a sensor inside the dizzy. you can't miss it.
80 bucks new from where? another guy got one for 88 second handOriginally Posted by VL Berlina 5speed
sorry didnt point out to look in the other product section of that link, but here it is
http://www.injectorsonline.com/indivprod.php?c=7
just scroll down to the electrical products, last product is a vl AFM new and the second to last is the CAS new
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
thank you berlina for your help u saved me spending 150 bucks lol
