Results 1 to 6 of 6
Thread: Car wont run on petrol....any ideas????
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Default Car wont run on petrol....any ideas????
    Hi there, I own a 1987 5 speed manual VL Berlina. It is running dual fuel but some reason it will run fine on gas just wont run on petrol at all.
    Has anyone had this sort of problem before and if so how was it fixed?
    Any help will be greatly appreciated........cheers
    Lets work as a TEAM and do it MY WAY!!
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Common problem, just save up for a few months till you can afford to fill the fuel tank.
    No sorry, just joking. I would try the fuel pump. That would explain things.
    vl berlina wagon 6cyl
    Jul 2005
    check the fuel pump fuses and pumps, there are usually 2 electric pumps, 1 in the tank and 1 behind it
    if needed, both are readily available in a choice of brands
    also look for a kinked or twisted rubber fule line
    EF Almost Turbo
    Jun 2005
    ok lpg.. how long since you ran it on petrol last?
    It could be blocked injectors, clogged fuel rail or lines, seized fuel pump, insufficent petrol?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    ^^ true, seals get dry and brittle if its not "flicked over" to petrol at least once a tank of LPG even just for 20 minutes or so to keep the fuel system fresh. Also the low preesure pump in the tank relies on petrol flowing through it to keep it from overheating and dying.
    ========My Statesman 20's Mafless and 3.9's========
    HSV VP Senator
    May 2006
    Quote Originally Posted by ucwepn
    Could be part of the problem.....I have the interior completely stripped at the moment and the car has been sitting in the shed for over 12 months, but when i bought it, it would only run on gas......
    You can hear the fuel pump when u turn the ignition on, so i dont think its that......but i could be wrong....when i get some time i will take the hose off the fuel rail and see if fuel flows out the hose and go from there......
    cheers for all the advice so far.....
  1. Runs on Gas and wont run on Petrol
    By Frabs in forum Electrical Wiring / Questions
    Last Post: 28-12-2006, 04:55 PM
  2. how much petrol in a vk?
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-05-2006, 08:04 AM
  3. Out of Petrol...???
    By wbd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2006, 10:20 AM
  4. Petrol
    By VS Omega in forum Jokes/Humour
    Last Post: 15-09-2005, 08:04 AM
  5. Just ran out of petrol
    By FXST01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 05:58 PM
