well i want as much info as u can give me, anything about pros and cons, theoirs and opinions,
i found out that there is no production valves made for the rb30, so boring it out to bigger flow is a bit more pricey,
i got a quate for gettn a head fixed
- head $83 from the wreakers with all cam and valves etc
- $25 to get it striped down
- $50 to get it presure checkd for cracks
- $50 to machine it flat
- $425 port & polish + overhual
= $633
or
- head $83
- $25 strip it down
- $50 pressure check for cracks
=$208
are these fair prices
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
All sounds good prices, but should get valves lapped in and valve seals done while it's off..Originally Posted by VL Berlina 5speed
Maybe get price on change over recon head too!!
Port if u got dollars and u don't need polish.. I'd go 4 a port clean up radiusing the bends in the ports and port matching if ur going 4 a cam later..
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
plus you need to put it on a flow bench if porting.
well that is intresstingThe theory is behind the way the exhaust manifold is situated..
The heat collects at the rear of the head on a na and thats where they crack..
Turbo models collect in a more central position that way the heat can dissipate more evenly..
Extractors help on na vls to reduce the chance of head cracking...
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
question. is there anyway to tell if it is the head gasket or cracked head with out taking it appart,
take a little while to drain the coolant in the overflow bottle, like a week or 2(i think).
would a cooling system pressure test tell waht is the problem?
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Someone told me they can test the head on the car and if its a minor hairline crack, a "chemical weld" can be done.
With regards to extractors, yeah that sounds right to me, the bloody heat sheild over the manifold traps too much heat and causes studs to become brittle and break, it only makes sense that the head would get heat damaged as well.
i didn't think there was any difference between N/A heads and turbo heads apart from the cam. how do they change where the heat collects?
i dont know that got me stumped,Originally Posted by bangers
and ucwepn is that check u talking about is it called 'pressure testing'?
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
when you get extractors doesnt that also pull the heat away from the motor ... causing it to take longer to warm up ? just a problem my dad had with his ute although he didnt have a thermo fan also is the fan supposed to run when the car is turned on from cold ? just curious on a vl i mean?
dan
Its Stock And it Rocks .... ditch the bitch lets go racing
Basically as i've told ucwepn before the rb30 mainly crack in the cam tunnel on the exhaust side and the crack's only going to get longer and make it harder to weld if it cracked you then need the cam tunnel rebored so the cam can move nice and free again. They also sometimes corrode through the water galleries and leak into the exhaust ports. The only difference between NA and turbo is cam we've compared the heads at work and there's no difference in ports vavles or similar things. The only way i could see heat difference is the turbo produces more heat therefore heating it more evenly. Pressure testing is when the water jacklets are sealed with a plate and compression is pumped into the water galleries it's then emersed into well basically water and bubbles will come out where a leak is. There is also vacumn testing where air is sucked out and if it holds a stables pressure normally would indicate no leaks. Pressure is far more accurute. Your top price sounds good pressure testing sounds pricey but worth it (peice of piss takes 5 mins). Chemical welding never heard of but its sounds risky. I'd say it might be quick fix but won't last long.
so there is no set way of telling if it is the head or the gasket with out dismaterlig it, and yah i read waht you have said in the other thread started by ucwepn and that was helpful infoOriginally Posted by Pub24/7
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
there is ways like water bubbles in radiator when engines running, Milky oil excessive steam from exhaust using lots of coolant overheating the basic ways. Oh sorry read your post better there ways but i'm no expert in engine diagnoses i just fix heads. But my opinion For example milky oil would to me indicate a cracked head as the crack would leak water into the the cam area where the oil is present. Bubbles would to me be a blown gasket as air be leaking into water galleries. Excessive steam could be either as water could be leaking into chambers or corroded through to ports. What sort of problems are you having?
You could still do a pressure test with the head still together but is not ideal. Vac test would be alright but then its not 100%
well i found a little bit of milky stuff undert the cap, stuck my finger in the rocker cover and couldnt fell any cream stuff or anything on my finger,
havnt notacied any steam coming out of the zorst, except the usal coldness in the morning,
ill check the bubbles in the radiator in the morning
the coolant was full when i got my car runnign fine and i notacied on saturday it was low at miniunum, so over two weeks it had dissepreard, so i think it is only a small crack or possibley a small brake in the gasket
couple weeks back i had some problems with missfirng and the CAS, i read on think it was calais turbo that the missfirng caused by stuffed head can cause the block to twist slightly and when you come to fit a new head it wont seal properly and jsut happen again, do you reackon the CAS/missfing could of had enough force to twist the head slightly causing the gasket to leak??
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
I think a blown head gasket will notice pretty quickly and tend to be almost instant overheat and lots of coolant in exhaust (if its exhaust side) My guess is you won't find bubbles but look anyway. I think you have to have some pretty high revs and under heavy load to cause the head to twist like if it misfiring at idle it wouldn't be the cause. Overheating will warp the head quicker. They're pretty strong qaulity alloy and really prone to softness but are very common at cracking. Out of batch of 20 we get at least half of them cracked (magna's are worse though almost all). Have you checked all other places for leaks like hoses, pumps heater welsch plugs radiator?
Basically with what you descibe it might be a small crack with the milky build up you decribe it might be worth changing the oil and see if its all milky.
ive looked over the piping and radiator, but ill check the welch plugs as well tommorow
just remberd i repaired a leak in my radiator about a year ago with alrolddite, ill give taht a look at and see if i can see it shooting water anywere when its hot
the car missfires slightly, but the rev guage dosnt bounce at all but if u stand behind the car you can hear it,
ill b back with more info tommorow, cheers for your help 2day Pub![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
No worries
pulld the dip stick out and its fine no liquard on it or creamy colour, and also i stuck my finger un side teh rocker cover and didnt find any of the creamy residue,Originally Posted by Pub24/7
dosent the cream take a week or so to apper? as it could be that my car might of picked up mostire while it was sat round for a week and half, was a wet week if i recall correct
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Yeah ive seen it before on 202's but if your oil looks ok then maybe it's not but hard to tell without looking at it. But i'm no mechanic or expert but i can fix cracked heads and do pressure testing straightning that sort of shit.
my old man jsut told me about something he and used a while ago when his capri had head probs,
he got a s/hand head from the wreakers and got this gasket called 'Monotourqe' which was think, he didnt get the head flattend and just fitted it with this gasket, and you dont have to retightent eh head again later
anyone hear about this gasket???
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
These gaskets have been around for years!!Originally Posted by VL Berlina 5speed
You can get a s/hand head and throw it on and have no probs or you could throw it on and need to take it straight off again.
Also machining the head gives nice fine grooves to get max sealing..![]()
o i started my car this morning and there was no bubbles coming up wheni had the cap off, was lookin for 30 secs or so till it started to get high, and after i got back from trade school i checkd the over flow bottle and it was at teh same spot as in the morning, so im confuseed now.. might be a very slow leak or small crack
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
Always check the level when cold, cause the water is pushed into the overflow as it gets heated and drawn back in when cooling..Originally Posted by VL Berlina 5speed
brb, ill check it now, cars been sat with the bonnet open for 3 hours now so should b cool
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
