Got home from work today and the car was leaking water had a look under the bonnet my water was just about empty then i seen small drips coming from one of the heater hoses anyone know what it could be its like its running down from the top and dripping in the middle of the hose its dark so havent had a good look but yeah if you know what im on about plz help.
those heating pipes are for the heater, it uses the cooling system to get the heat sorce to genirate the heat, it might be leaking on the inside or near the fire wall possible rubbed agains the fire wall causing a hole (need more details on the possition), refill the radiator and overflow bottle and BLEED it, as this is a very tense thing that is happening, as if you lose to much coolant the air will get in your system and then bye bye head
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
I would like to change those 2 heater rubber hoses, down the back
how difficult is it? do you need specially shaped hoses or can straight hose be used?
the heater valve is under the dashboard and is controlled by a vacuum operated motor, the vacuum hose had fallen off mine
Just ring up a parts mob and order them mine were like $7 each from eagers, BUT thats not my prob mine is this small metal fitting that goes into the engine it has 2 hoses coming off it its like its all rusted out so yeah it will be a fun job can anyone tell me if they have done this because i dont wanna snap it off because i thinks its pretty fked up
best description i could do couldnt find any engine pics..
Ok if the fitting is attached to the head be very very very careful when removing and replacing it because if you strip the thread you are f%cked. The head is alloy and I have had similar dethreading probs in the past.
Get a workshop to fix it, prolly take them 5 mins and they might just charge you for the part if they supply it. Most workshops want to build a good customer base so they will try and help you out. And if the workshop strips the thread they are up for fixing it.
its at the back bottom part of the engine theres one at the front aswell but yeah i think im going to get someone to do it seems to risky and hard to get to.
