Results 1 to 7 of 7
Thread: vl compter what is it?
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    Default vl compter what is it?
    hi,
    what it the point of the other cumpter thingo in a vl. there is the main eng/gearbox one but what it the other black plastic one used for??
    cheers
    jason
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    both my computers are silver/metal. 1 for eng and 1 for auto g/box.
    where is the one you are referring to located?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    yes there are 2 ecu's one for the engine management and the other is for the jatco automatic. They are both located inside the car and both are either silver or gold coloured. The only black plastic thing I can think of is the fuse relay box under the bonnet right in front of the passenger side.
    ========My Statesman 20's Mafless and 3.9's========
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    there is a plastic box under the steering column which is for the standard alarm
    Apr 2006
    hmmm ok here is a pic of it go to ebay item number 220014397432
    hope that helps. cant rememb where is was in the car tho.
    cheers
    jason
    VL
    Jul 2006
    adelaide
    the black box is bolted up inside the drivers side kick panel with 2 plugs going into it, from memory its the control module/box for the window wipers.
    Apr 2006
    ah yeh thats prob what it is.
    cheers
    jason
