Results 1 to 19 of 19
Thread: Spitting oil out of exhaust
    VL Berlina
    Apr 2006
    Default Spitting oil out of exhaust
    Hey, today i was cruising around town and my mate was behind me in he's car, we pulled over at my friends house and he said my car was spittiting something out the exhaust so i started my car and got him to rev it and it was spitting oil out of the exhaust, it seem's once the motor is warm it doesnt spit oil but when it's cold it spit's. Today i was at my mate's picking up a car to rally thru the bush, he's dad is a mechanic and i told him my problem he said "your motor's fingered", he said that the piston ring's were worn or something. Do you guy's think the same? Should i get a compression test? if it does have worn ring's im guessing it will cost around 1k+ to replace them so i may aswell just try and find a cheap rb30 engine or a vn engine or something insted of getting it rebuilt???
    Also when my car is cold i will go to take off and it sounds like one of the fan belt's or something is rubbing, its very loud? But if i let my car idle for a minute of two and go to take off it's fine???
    Thank's.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by qwertsta
    Thank's.
    None of us here can see it so , I'd say it's just condensation and the black soot that unleaded makes when the car's cold as when warm no more condensation..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL Berlina
    Apr 2006
    Hey thank's for the reply, the oil is a fresh brown. So it is comming from the motor.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'm leaning towards condensation aswell, as much as it may look like oil or petrol its more than likely condensation. I'd be under the impression that if oil was in the exhaust it'd be burning or smoking pretty prefusely.
    Anymore reasons why you think its oil?
    VL Berlina
    Apr 2006
    Because you put your finger in the exhaust and you are left with oil on your finger (brown lubricant), sound's like im talking dirty but im not and yes if you turn the engine off the oil what what is around the rim of the exhaust smoke's a little bit.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    are you using oil? and i'd tighten the fan belts, if the noise is still there then replace them.
    VL Berlina
    Apr 2006
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    well, if you're losing oil out the exhaust, are you losing oil in the motor, has it gone down on the dipstick
    Bax
    Nothing
    Jan 2004
    QLD
    Have you checked your oil and noticed that the level is going down?
    Using oil that is
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    VL Berlina
    Apr 2006
    That is something i have not checked yet, it's to late to check now i will check tomorrow. If their was to much oil in the engine would it be going out the exhaust or is there like a breather tube or something for the engine?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Oil should not find its way out of the exhaust, if it was there would be plumes of white smoke coming from your exhaust when driving. If 1 or more rings are gone this will also cause the engine to run poorly and lose power. It could be water condensation as others have mentioned. could also be a blown head gasket (allowing water to seep into the combustion chamber and out a port or 2 pushed by the force of the exhaust, when the motor gets warm the water is evaporated.)
    Could be a kind of cold start mode where the ecu dumps fuel through the motor when cold to help prevent startup wear and its simply unburnt fuel.
    Any liquid that finds its way out your exhaust will be black/brown because the inside of the exhaust system is usually caked with carbon and other deposits over the years.
    Try collecting some in a cup and see if it ignites with a match. That will at least rule out the rich start mixture theory.
    ========My Statesman 20's Mafless and 3.9's========
    VL Berlina
    Apr 2006
    Okay, today it did not do it at all. I checked the oil and it's fine. Maybe it just was condensation after all? Thank's for the help guy's.
    prince_dj666's Avatar
    prince_dj666 is offline hypo v6
    http://www.cardomain.com/ride/2112842/1
    Oct 2005
    QLD
  15. #15
    Oct 2005
    QLD
    no comment..........
  16. #16
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Thank's.
    My car spat shit out the exhaust that looked like oil, I could show you the stains on walls gates and other cars as it spat shit out very bad, Only when cold never when hot, But i seen little black dots all over the back of my car, When i gave it some foot it would blow smoke not always but it wasn't looking good, But it still ran fine oil was always good everything was fine but i couldn't work out why it was letting loose like that, I covered my sisters front bumper with shit once.
    So anyway i just had my exhaust done, And i was given a option of Hi-Flo Cat for the price of a stock one, So i though what the hell lets get that done.
    When they took the old cat off it was burnt out and blocked up with crap that looked like what was coming out the exhaust. they say you are meant to be able to see through the cat but you couldn't see through myn.
    Since it's been changed and the exhaust also nothing and i mean nothing comes out my exhaust anymore no smoke no oil looking stuff nothing at all no black dots on the rear of the car nowhere. Lucky i didnt think my engine was toast and get a new one.
    Maybe you might have the same problem???
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  17. #17
    vl berlina wagon 6cyl
    Jul 2005
    dirty water is normal until the exhaust warms up, it then comes out as water vapor which usually isnt noticed
    moreso on humid days, also on short trips, the engine oil becomes contaminated with the water, making the level increase on the dipstick
  18. #18
    VL Berlina
    Apr 2006
    Quote Originally Posted by SlickHolden
    Thank's for the info mate, i might have to get that checked out next time i take it in for a service.
  19. #19
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    NP mate, Hope it's not even that and it's nothing at all.
    With me i shit i was thinking my donk is dieing i need a new engine But them bloody dead cats make a mess
  1. Petrol spitting out of the exhaust
    By JD in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2007, 05:19 PM
  2. heater spitting waterh
    By lasco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 12:37 PM
  3. car spitting out black stuff
    By silvr6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2006, 01:32 PM
  4. Backfiring or Spitting Back
    By petwoofer in forum General
    Last Post: 28-10-2006, 10:56 AM
  5. Spitting Coolant Help!!!
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2006, 11:59 PM
