Results 1 to 4 of 4
Thread: Blowing fuses
    VN SS
    Apr 2004
    Default Blowing fuses
    my sister has a vl berlina and i have been trying to fix this problem of her fuses blowing.
    i so far have replaced the entire fuse rail in the passenger side engine bay (as the old 1 was melted and warped) everythin seems to be working fine except fuse no 4, which is the dash lights and stuff. now firstly what size fuse is meant to be there, also what are all the components that that fuse controls, as i want to start checking what might be causing the problem.
    any other info people might have is appriciated, thanks James
    Caution: Vehicle Frequently Sideways!!
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    My VN kept blowing the dash light fuse when I got it. I bypassed the circuit because the wire insulation was melted! and hooked the dash lights up to the headlight switch. The dimmer doesnt work now but I only have my dash lights on full anyway.
    I found the problem this weekend, it was the light in the t-bar shorting on the metal. The wire insulation was melted all the way up to the t-bar. I still dont have lights on the t-bar as I would need to re-run the wiring and cant be bothered as i know what gear im in anyway!
    Im not a complete idiot, some parts are still on backorder!
    Little John Guest
    Default Blown light fuses
    HI, Ive had similar probs, and found there to be too many Watts in the lights for the fuse. Simply add a relay for the extra wattage.
    VN SS
    Apr 2004
    hi people thanks for the info i have tried both and the wiring touching the t bar seemed to be the prob, even though there are a few probs with the lights as they arent very bright and when i turn them and highbeam on my amp guage goes down to about 12, which is obviously no good, thats the next prob i will look at.
    thnaks James
  1. wk blowing fuses
    By caprice123 in forum Electrical Wiring / Questions
    Last Post: 23-12-2006, 09:09 PM
  2. blowing fuses
    By lurkin308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 10:12 PM
  3. blowing fuses
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-06-2006, 12:06 AM
  4. Fuses Blowing
    By jamiekratin in forum Car Audio
    Last Post: 24-03-2006, 05:37 PM
  5. Amp Keeps blowing Fuses
    By Darkwander in forum Car Audio
    Last Post: 26-02-2005, 10:26 AM
