Results 1 to 12 of 12
Thread: vl turbo help
    kaptan7 Guest
    Default vl turbo help
    1st thing is to say,g'day!!new to here and already have learnt alot,thanks guys.ok now some questions.i have rb30et with a bleed valve.about halfway down the bleedvalve there is a little hole in the side,should that hole create vacuum?eg,i can pour detergent on it and it is sucked into the hole?next one is why would sump oil come out my bov?when i had it fitted it didnt work for ages,i took it back and the mechanics took one of the hoses off the fuel canister and put a ball bearing in,does this sound right?thankyou!!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    kaptan7 Guest
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    you may have a crack in the turbo housing!? i'm no expert though.
    also where is the bleed screw you're talking about?
    kaptan7 Guest
    it is a turbosmart item and it is about halfway from the top(where the round handle thingy is) to the bottom.possably where the grubscrew is.is there such a thing as a worn out bleed valve,it is pretty old.could not idling the car after a drive crack the turbo housing?thankyou.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    kaptan7 Guest
    well there you go then,the mechanic who rebuilt my motor and turbo 18 months ago,for 7grand mind you,said if you are just driving round normally ,you can turn it straight off .but if you have just raced flat chat up the great dividing range,then let it idle for a couple of minutes.okey dokey,i guess the next question is does anyone know and trust a mechanic in brisbane,i would like to take it to somebody different.thanks for your help as well.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    if you spent 7g why didn't you spend an extra couple of hundred on a turbo timer?
    kaptan7 Guest
    because i was told by the person that it was not needed and as i dont live in toowoomba,i trusted him.
    VT SS S2 A4
    Aug 2005
    How much oil is coming out of the bov because if it isnt alot it is just blowby, nothing to be overly worried about.
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    id start of by doing this.
    fir oil catch can for blowby, this is the cause for 90% of the problem, the other is the turbo seal.
    fit catch can, remove piping eg intercooler and clean, and refit and see how it all goes from there.
    The bleeder valves all have holes there, leave it dont worry about it.
    just make sure when u fit the catch can system, u do it correctly as ive seen so many people have running problems after, when your ready send pic and ill describe what to do.
    kaptan7 Guest
    cool,thanks guys,i only run 10lb boost so i dont have an intercooler yet.ill shop round for a catch can and get back.thankyou.
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  3. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
