Results 1 to 6 of 6
Thread: exhaust rumble
    adrian222's Avatar
    adrian222 is offline VL 5 speed now on 18's
    VL 3.0L 5 Speed
    May 2005
    nowra
    Exclamation exhaust rumble
    my exhaust has a rumble and there is no hole in the exhaust itself. would there be a leak or somthing somewhere else that would cause this. back fires sometimes but not often.
    Girl Torque's Avatar
    Girl Torque is offline VL Calais 5L
    VL Calais.. etc
    Sep 2005
    SA
    might be the exhaust gasket (gastket between exhaust and the head) - stick your head in the engine bay while she's running and see if it sounds a bit 'fluffy' - do it while it's cold and then you can touch around the gasket without burning yourself
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Sabby's Avatar
    Sabby is offline MSABBY
    VU SS FIFTY
    Sep 2006
    melbs
    same happened to me, i jus bought new extracters and exhaust system, it was probly the gaskets tho.
    runs fine now
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    what about a slight leak where the exhaust manifold connects to the exhaust itself?
    We got rep back, yaaay!
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    Quote Originally Posted by JDZVNHSV View Post
    i belive that's what bangers was getting at.
    have you checked for cracking in the welds around the mufler?
  1. rumble noise
    By tonys vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2007, 08:24 PM
  2. Rear end rumble
    By Moet246 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-03-2007, 03:08 PM
  3. big rumble
    By 03vyPplater in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-01-2007, 11:18 PM
  4. Rumble and grind!
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2006, 09:14 PM
  5. Bad Rumble!!!
    By Wombatclay in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 09:30 PM
