Results 1 to 4 of 4
Thread: VL mods
    ***cOdi*** Guest
    Unhappy VL mods
    Hey guys n gurls, just wanting to know if u think i should buy a turbo for my VL or buy a Full turbo Engine...?? i really dont no. also if any one has done an Auto to Manual Conversion and found any little problems... i am about to do it n need to know as much as i can...!!!!!!!! cheers
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    well you will need to cut into the body where the shifter goes, the clutch cylinder mounts up perfectly, already has the bolts, so that's easy, the clutch will be a real pain, get someone who has done one before to help you out.
    Are you doing it at home with the car on stands or on a hoist? DONT DO IT WITH A JACK SUPPORTING THE CAR!
    if you could get one, get a rattle gun, less time under the car straining yourself doing things up tight.
    i dont reckon it would be that hard.
    might wanna take the shifter out before you put the box in, it'll probably make it easier, not hard to take it out or replace.
    Good Luck.
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    there's already a thread on here in regards to converting the gearbox. do a search. it's probably on page 2.
    also with the turbo it depends if you want a standard tubo motor or a worked one. get a series 2 engine and build it yourself, atleast then you know whats done.
    VL Calais
    Dec 2005
    Quote Originally Posted by Stewart1000
    Good Luck.
    Shouldnt need to cut anything. Just drill the rivets out that hold the metal surround, then if you have the manual one rivet that in. Too easy and much neater finish.
  1. vk mods`!!
    By Vkcalais8 in forum General
    Last Post: 22-11-2006, 09:23 PM
  2. First mods.
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-11-2006, 05:21 PM
  3. VR mods.
    By Cannon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2006, 08:53 AM
  4. mods to VT CAI
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2005, 06:26 PM
  5. vx mods
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2005, 08:44 AM
