Results 1 to 6 of 6
Thread: power steering onto vl
    vl sl 5spd 6 n/a turbo convert '88
    Apr 2006
    Default power steering onto vl need info asap
    hey guys i'm in the process of buying power steering for my car and was just wondering if anyone on here would be able to give a list of everything that is needed? i picked up the pump, resovoier (spelling) and two of the hoses tonight (two shorter ones). how much am i missing? i know theres at least the power steering rack and one other hose that i need (missing the long hose), but not completly sure on everything i actually need. i also need this info asap please as the guy lives an hours drive away and i didn't want to go down a 2nd time, but i got to now and i definatly do not want to need to go down a 3rd if i find out that i am still missing something after i go down again. cheers.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default parts
    Quote Originally Posted by hosedogg
    Have u got the bracket to hang the pump on, and bracket to hold the reservior in place, bolts that u may need.
    Can't think of anything more at the moment..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VS Commodore Acclaim
    Jan 2006
    Plus intermediate column shaft - the one with the universals at each end as input spline is different and length is different between manual steering and power.
    VL SL 5spd
    Dec 2005
    Pump
    Pump Bracket + 3 bolts + 2 pump adjusting bolts - can't just use any bolt, needs to be the genuine ones.
    Fluid Reservior (don't really need the bracket)
    Lines:
    2 metal ones which should have short rubber hoses connected to them..
    1 metal one has a short rubber hose connected on the end, which goes to the pump, the other end is a screw fitting, goes to the rack
    2nd metal one, runs from the pump, then under the radiator, then up, has a rubber hose connected on the end, and goes to the reservoir.
    Then there's a 3rd rubber hose, that goes from the reservoir, to the rack.
    Have fun installing it.
    As stated above, you MUST get a intermediate shaft taken from a power steering car, the manual one will not bolt up.
    To remove the old intermediate shaft, you have to get under the dash steering column, rip out the rubber boot, and undo one bolt.
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah thats true about how to get the intermediate shaft out. If you are finding it hard the whole steering collum is attached by 3 nuts, 2 up front and one down the back and then the whole collum will come out and you will be able to do it easily.
    the clamp bolt (youll know what i mean when you see it) that was on my 2 cars seemed to be something like 17.5mm 18mm was too big and 17 too small i ended up using an 11/16 im pretty sure. good luck. Also dont get atf on your skin, its very bad it gets into your pours very quickly.
    Good Luck
    Stewart
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    Apr 2006
    awesome thanks for that guys. the guy's coming down here some time next week with it. the pumps still on its bracket, the resevoir has that metal bit around it with a bolt in one side, but i'm guessing that wouldn't be tha whole bracket. i'll have to ring the bloke tomorrow to tell him i'm going to need the intermediate shaft also, cause atm he'll be bringing down the rack, the low pressure hose and all the bolts. i'll buy a new belt as mine needs to be replaced soon anyway. heh i get atf on my hands all the time at work (mechanic), but that gets washed off more or less straight away. thanks again for the help guys. cheers.
  1. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  2. Power steering Vs. manual steering?
    By cruzncommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2007, 07:45 AM
  3. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  4. power steering!!!
    By munchmunchrotors4lunch in forum V6 Development And Modification
    Last Post: 25-10-2007, 07:57 AM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
