Results 1 to 14 of 14
Thread: CAI in VL Commodore
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Default CAI in VL Commodore
    Can you install any Cold Air Intake Kits on the VL commodore, such as taking the VS Supercharger Chute and place it on the VL?
    Or what other options do I have, btw I have opted not for the POD as for the noise it makes.
    Thanks
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    I don't think it'd be doable. They're trouble enough on a VN/VP. I put one on my VP but not without it's hassles.
    I might pull mine off my car and test fit it to my gf's VL and see how it goes.
    Life's Grouse in Frankston South!
    VL
    Jul 2006
    no i doubt it will work using anything from a later model. basically you have these options:
    1. Pod - which you have said you don't want so thats a no
    2. cutting a big dirty 100mm circular hole out of the body under the airbox and running some pvc out to behind the front bar. the hole is illegal and defectable but many people still do it. apparently it works well but i don't reckon its worth it
    3. this is what i have done: first off a K&N panel filter replacing the standard paper one, then i threw the plastic duct away and cut the hole in the front of the airbox to roughly twice the size. then i made a new wider duct out of sheetmetal and attached that to the airbox. now air is drawn into the airbox from the corner right up behind the headlight. i noticed the difference over standard but haven't compared it to the hole in the body method
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    There should already be a hole under the airbox that has a plate spot welded over it. I just knocked the plate out with a hammer and screwdriver then cut a hole in the airbox to line up with the hole below then used 90mm plastic pipe which finished behind the front bumper.You can buy the pipe and bends to suit from any hardware place.
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    hmmm.... Getting there with options.... If anyone else out there have some more or different options that would be great. Opinions are welcomed as to which way you would go about trying to get more air intake. Or is a POD still the best option.
    VL
    Jul 2006
    Quote Originally Posted by Tree cutter
    did you notice much difference with just that existing hole? its only about 40mm in diameter isn't it?
    and pods aren't much good because of the temp of the engine bay air so i don't think there is much point doing that. UNLESS you put a CAI to the pod (piping through the body to it) or box it and seal against the bonnet to keep hot air out
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    All I've taken out the snorkle, and made a larger hole in the Air Filter box. Had the Air Filter base cut larger to accomodate a Genuine Holden Cold Air Intake Duct, The air seems to be blown in by the fan from the Radiator. I have noticed a difference in power, acceleration and also smoothness in gears changing. Will look into cutting a hole on the bottom of the box and through the car body, possibly run a pipe to the front of the bumper.
    VL
    Jul 2005
    SA, Mount Gambier
    Heres a thread from Calais Turbo which a simular thread has been made on here before.
    http://www.calaisturbo.com.au/showthread.php?t=17106
    They made a cold air intake, well worth the look.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i just got a good filter * K&N * and cut a dirty big hole in the front of the air box, Thats it. i noticed a difference in the noise. Alot more deeper BUT i have standard exhaust so ....... no good gettin the air in there fast if it dont come out fast hey
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    well the CAI of the vs wouldnt work the best as the vls nose cone covers the bonnets intake line causing the air flow to be disturbed,
    but the pvc piping under the box works wonders ive got it on mine as well as a k&n panel,if i place my car in nutral while at 80+ going down hill the car stalls as to much air is getting ramed in causing it to choke on air, and i have also made the box bottom part fully open all the way,
    it seams more resopnsive when ive got the CAI open but when its winter i place a cap over the entrance and its a tad bit slugish
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    Make up a box for a pod, then you won't really hear the noise as much.
    Soon to be back on the road, Turbo VG.
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Making a box around the pod, wouldn't that restrict the air getting into the engine?
    VL
    Jul 2005
    SA, Mount Gambier
    coastvl's Avatar
    coastvl is offline Member from the dead!
    VZ EQUIPE six
    Jun 2003
    Hervey Bay
    That CAI on CT is mine. It's been there for about 6 years now and has never been a problem. I've been through a foot of water with it too and had no dramas at all.
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  3. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
