Results 1 to 12 of 12
Thread: will the box be OK?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Question will the box be OK?
    as most of you know i'm doing all sorts of mods. my next one (God Willing) will be the gearbox conversion. i have a doubt as to whether the box i have will handle the power. its an rb20det box. i'm pretty confident it will be ok on my NA 6cyl but will it handle the power when i put the turbo motor in (eventually)?
    should i just sell the box and save a bit more and source a rb30et or rb25det box?
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i thought i remember sum1 sayin that the rb20 box is very similar to the rb25 box ..... either that or they said its crap lol. i dont really remember now ...
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    the rb20 box is similar to the non turbo rb30 box.
    it should be right, for a while at least. definately factor in an upgrade for an r33 box.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    just clearing some thing up hear
    -rb20 (r33?) box is simular to na vl 5spd
    -rb25 (r32?) is same ratio as the na vl 5spd but strength of the turbo box and has twin sincromesh
    -rb26 (r33?) best box of them all?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    hey bax i know the gear ratios are the same between those 2 boxes but is the rb20det box stronger?
    Bax
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by VL Berlina 5speed
    -rb20 (r32) box is simular to na vl 5spd
    -rb25 (r33) is same ratio as the na vl 5spd but strength of the turbo box and has twin sincromesh
    -rb26 (r33) best box of them all?
    just changed those two first ones, i've also heard that the rb26 box is just the r33 box with a transfer case added.
    bangers im going to have a look but im fairly sure they were the same, if your after decent power then i'd go the 33 box, you can get one setup for around 2k, definately nowhere near as cheap as the 32 box at around 400 dollars. But you get what you pay for.
    As far as I know they just had twin syncro's or something extra, not sure. Google search?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    please have a look bax, thanx. I've done a fair bit of enquiring but a lot is hearsay. and nissan know shit all.
    VR EXEC
    Nov 2005
    Quote Originally Posted by Bax
    bax is on the money
    Bax
    Nothing
    Jan 2004
    QLD
    bangers I can't find any information about the box - I can tell you all you want to know about the mf5 and the mx7, but to be honest I don't even know the codes for the r33det box, apparently the rb20det and the rb25de boxes are the same.
    keep in mind its torque that kills gearboxes. the reason why the rb20det box may last is exactly that, because its only an rb20det, lots of power but not as much torque, bolt it to your rb30 and she may rip it to shreds.
    having said that though, it has been done and people have nursed them - but with your engine, and i doubt you'll want to nurse it. definately upgrade to a 33 box... 1200-1800 for the box, 400 for a decent clutch, 30 dollars for the speedo converter. install, pedal box, slave cylinder and your in business.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i've done some more googling. the rb20det stock put out 214bhp and i'm hoping for @300bhp so i think the box should be ok. but as bax said its down to torque. anyone else have any ideas?
    VK wagon
    Aug 2006
    NZ
    My brother has a cefiro with RB20det and std man box. Its got 180kw at the wheels(dyno) and he thrashes it and the box just keeeps going... in saying that any box will give up if you give it death all day...
